Old 06-08-2014, 03:07 PM   #21
ronn
Default Re: To paint or not to paint a trailer floor
Mot, bedliner could be pretty pricey. Also not as easy to wipe up as epoxy or latex.
You are right though, would probably last longer then the trailer.
Old 06-09-2014, 08:25 AM   #22
denis4x4
denis4x4's Avatar
A couple of drops of oil is nothing compared to horse urine and poop that is the byproduct of trailering horses! I used rubber trailer/stall mats from Big R and Tractor Supply. About $50 for 4' X 6' X 3/4'. In fact, I have put them down through my entire shop as they are easy to walk on and impervious to oil.
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 06-09-2014, 03:20 PM   #23
Big John
A few yrs back, i was at a car show in midland , mi....the guy has a nice old bujck in an enclosed trailer and the floor was covered with carpet with the buick logos on it... like you might have found in an old dealers showroom many years ago...... very neat....
Big John is offline   Reply With Quote
Old 06-10-2014, 07:39 AM   #24
elklake
I purchased a used 20' 2012 enclosed trailer this year and the previous owner applied the roll on bed liner.
I works great! - Easy to clean, durable and good traction. I would recommend it.
elklake is offline   Reply With Quote
Old 11-14-2016, 01:28 PM   #25
Chris H
Chris H's Avatar
Not a trailer, but when I built my shed for storing lawn mowers and such, I sealed the pressure treated plywood with "Kilz", then 2 coats of acrylic porrch and deck paint. That was over 10 years ago. With some leaking gasoline and motor oil, and who knows what else, it has held up very well. There are black tire marks, but no signs of peeling or lifting of the paint. Granted, it almost never sees any water, but would think the oil and gas would be harder on the finish. I would rather have used a good oil based deck paint, but it just isn't available around here.
Chris H.
1930 Tudor
1964 MGB
1979 MGB
Ham call: N9WHH
Chris H is offline   Reply With Quote
Old 11-14-2016, 02:05 PM   #26
Ron in Quincy
Ron in Quincy's Avatar
Dean,
Look into Rustoleum 10X, it comes in a large varieties of colors, it is applied with a roller, it is for horizontal surfaces, is 10 times thicker than paint, has a rough surface when dry, takes 48 hours to dry, must be 50 to 90 degrees when applied, actually made to restore old wood decks.
Ron
They also make a 2X which is for vertical surfaces, can be applied with a brush or roller, twice as thick as paint, needs to be applied at 50 to 90 degrees, comes in the same colors.
Ron in Quincy is offline   Reply With Quote
Old 11-14-2016, 03:09 PM   #27
29Cabriolet
29Cabriolet's Avatar
FWIW, My Cabriolet lives in a pre-fab garage with pressure treated plywood floors. I was concerned about oil and grease too. So I painted the floor with gray deck stain. Grease and oil "droppings" do not soak in as they would on bare treated plywood and is easy to clean up.
29Cabriolet is offline   Reply With Quote
Old 11-14-2016, 08:32 PM   #28
majohnson00
My 20 footer has three coats of Pollyeurathane, looks great and wipes any oil or tire marks easily.
majohnson00 is offline   Reply With Quote
Old 11-15-2016, 01:52 AM   #29
TerryH
TerryH's Avatar
Several years ago I had an enclosed trailer, and a friend suggested using inexpensive self stick vinyl flooring that came in squares. This worked extremely well.....very easy to sweep out or wipe up oil drips.
TerryH is offline   Reply With Quote
Old 11-16-2016, 05:52 AM   #30
hazelhoff
hazelhoff's Avatar
Try Owatrol which is an oldfashion protection for yaught decks. Will do for outside usage.
hazelhoff is offline   Reply With Quote
Old 11-16-2016, 06:56 AM   #31
ronn
so everyone has an opinion- in the end, doesnt really matter what you treat it with-will be better off
for treating it, rather then not..............
