Old 08-24-2016, 11:14 AM   #1
Bulligen
Bulligen's Avatar
Default 97 Carb Fuel Bowl
Can anyone tell me how the fuel bowl is vented on a 97. Mine seems to not want to accept fuel. It will take on fuel from a electric pump when the engine is not running and then when I start it up it will run just fine until it runs out of fuel. The moment the engine stops the fuel bowl will fill back up and it will start right up and burn the fuel till its gone. I can watch this happen through the clear fuel filter that I have inline. I also notice the fuel filter is never filled with fuel, it is half air all the time. The float is set as it should be. It just seems that there is pressure in the bowl that prevents the fuel flow into it when the float drops. I have tried the needle style and the grosse valve with the same results ? Any Ideas ??? Its driving me crazy!
Bulligen is offline   Reply With Quote
Old 08-24-2016, 11:44 AM   #2
Bruce Lancaster
Default Re: 97 Carb Fuel Bowl
Vent is the slot where you hook the accelerator pump return spring.
Start looking at filter and at possible air leak between pump and tank
Old 08-24-2016, 12:18 PM   #3
Bulligen
Bulligen's Avatar
I will check those out, Thank you very much!
Old 08-24-2016, 04:19 PM   #4
Bulligen
Bulligen's Avatar
Any other ideas!
Old 08-24-2016, 04:32 PM   #5
quickchange34
quickchange34's Avatar
Sounds like you don't have enough fuel coming to the carb. Do you have a fuel filter before the pump that could be stopped up or the gas line loaded with rust or hole in the line which will cause your fuel system to get air. The fittings may be loose. Good luck!
quickchange34 is offline   Reply With Quote
Old 08-24-2016, 04:58 PM   #6
ht murg
Fuel pump wired hot when ign is on or just when cranking
ht murg is offline   Reply With Quote
Old 08-24-2016, 05:05 PM   #7
Willit Stop
Willit Stop's Avatar
A few things off the top of my head.....
-The float may be sunk.
-Wrong gas cap (non-vented). Remove the cap and see if that helps.
-Remove the fuel line from the carb,shove a rubber hose on and put the other end in a quart jar.Turn on the electric pump to make sure you have a good flow.
Is the pump still working when the engine is running?
Beyond that, I'm stumped.If it's still driving you crazy,you could join my support group?(Just kidding) Good luck.
Willit Stop is offline   Reply With Quote
Old 08-24-2016, 05:17 PM   #8
Bruce Lancaster
An addition...split the possible problem areas. Solder a short pipe to something like a thinner can, hook it to carb as gravity feed. Unplug the fuel pump so you are not immolated during the experiment!
if the thing fires up and keeps going, problem is aft of the carb. If behavior does not improve, time to yank the lid on the carb.
Old 08-24-2016, 10:50 PM   #9
Bulligen
Bulligen's Avatar
The Pump has good flow, pumped fuel into a bucket , It has about 3 lbs of pressure. I thought that was too much, I put a regulator on the line at 2 lbs , still acts the same way. My next step is to gravity flow it and see what happens I guess ???
Old 08-24-2016, 10:52 PM   #10
Bulligen
Bulligen's Avatar
I have the electric fuel pump wired on its own toggle switch, independent of the ignition
Old 08-24-2016, 10:54 PM   #11
Bulligen
Bulligen's Avatar
The carb is a brand new English Stromberg 97 all adjusted at the factory.
Old 08-24-2016, 11:43 PM   #12
Mike in AZ
Mike in AZ's Avatar
you checking the pressure with pressure gauge?....Mike
Mike in AZ is offline   Reply With Quote
Old 08-25-2016, 08:28 AM   #13
Bulligen
Bulligen's Avatar
My neighbor brought over an extra regulator that had a gauge on it and connected to that only, plugged at the other outlet the gauge read 3.1 lbs. I put a cheap regulator on it and will check it again. Do you think the pump in sucking air from the fuel tank?
Old 08-25-2016, 10:00 AM   #14
Willit Stop
You mentioned that the carburetor is new.Maybe you could swap it out with your old one and see if there is a difference. Just a thought.Sometimes, new doesn't mean good.
Old 08-25-2016, 10:38 AM   #15
weemark
3.1lbs is too much pressure, try 2lbs
as a test hook up a container with some fuel in it to the carb and hold it higher than the carb so it gets a gravity feed rather than pulling fuel through a pump from your tank.
EDIT: sorry just seen bruce suggested hooking a temporary fuel source up to discount where the fault may lie.
tbh sounds like something is blocking your fuel pipe when the pump is running, I would be surprised if its a carb issue.
weemark is offline   Reply With Quote
Old 08-25-2016, 01:03 PM   #16
Bulligen
Bulligen's Avatar
I am going to do just as you guys have suggested and set up a gravity fuel source tonight and see what happens. The old original carb did the same thing as the new one that is why I though I would just buy new instead of rebuild? Could the electric fuel pump be drawing air and fuel from the tank at the same time therefore always having fuel with voids of air in the lines. The inline fuel filter which is standing upright in the line going to the carb is never full of fuel at best it is 1/3 full. Also as the engine stumbles and dies, right at that moment I can view a surge of fuel through the filter going to the carb but too late to keep it running ??
Old 08-25-2016, 02:03 PM   #17
weemark
Sounds more like the pump is sucking something in the tank into the fuel line. When the pump dies the debris can float off as there is no suction hence the line is clear again until you start it again.
Old 08-25-2016, 02:29 PM   #18
barnfind
I would bypass the old fuel line with a temporary fuel line. Rust or debris in the tank could be blocking the outlet acting like a flapper valve as weemark suggested.
barnfind is offline   Reply With Quote
Old 08-25-2016, 02:50 PM   #19
Bulligen
Bulligen's Avatar
The tank is brand new inside
Old 08-25-2016, 02:58 PM   #20
Bulligen
Bulligen's Avatar
Every line is brand new as well. This is why its driving me nuts!
