09-22-2015, 04:46 AM | #1 |
35 front brakes on 32-34 spindles
Just seeing if I can put 35 type front brakes on 32-34 spindles ,,,also is there a difference in 36 spindles ,,,? Thanks from Rod ,,,
09-22-2015, 07:26 AM | #2 |
Re: 35 front brakes on 32-34 spindles
G'Day Rod,
There is a difference between '35 and '36 spindles.The spacing between the tie rod holes on the '36 LH spindle is wider by about a 1/2 inch and the spindle length is around a 1/4 of an inch shorter than the '35 one . I'm not sure about the brake bits fitting though. |
09-24-2015, 04:29 AM | #3 |
Thanks for that ,,,I had seen that the 36 type are slightly different ,,I am after a set of 35 RHD ,,so I hope I can recognise them ,,,regards Rod,,
09-24-2015, 06:09 AM | #4 |
hello Rod is it the wider drums you are after?
09-24-2015, 07:02 AM | #5 |
Rod, you can put the '35 front brakes on '32-'34 spindles but you will need the spacer normally used for a juice brake installation.
09-24-2015, 07:12 AM | #6 |
1928-1934 Front Spindle Adapters, $20 plus shipping for the pair. |
09-25-2015, 05:44 AM | #7 |
Thanks for the info ,,,
