Old 06-01-2015, 09:42 PM   #1
david.skinner
david.skinner's Avatar
Default Wheel nut torque ?
What is a reasonably value to use on the wheel nuts of my wife's 36 pickup. Please note that is really a roadster with a colonial cab on it so its got car wheels on it.
Ta.
D.
david.skinner is offline   Reply With Quote
Old 06-01-2015, 09:54 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Wheel nut torque ?
I like 65# torque.
Old 06-02-2015, 12:25 AM   #3
Phil Gillespie
Phil Gillespie's Avatar
Front or rear? There is a considerable difference!!
Phil
NZ
Phil Gillespie is offline   Reply With Quote
Old 06-02-2015, 12:31 AM   #4
Charlie Stephens
Do you mean the ones that hold the rim to the drum or the ones that hold the drum/hub assembly to the axle (rear) or spindle (front)?
Charlie Stephens
Old 06-02-2015, 12:45 AM   #5
david.skinner
Actually - All of them - I just want to make sure they are all done up appropriately given the lack of use the vehicle has had.
Many thanks.
D.
Old 06-02-2015, 05:38 AM   #6
toby
toby's Avatar
1949-1951 Ford per shop manual- 65-75#
toby is offline   Reply With Quote
Old 06-02-2015, 07:40 AM   #7
51 MERC-CT
51 MERC-CT's Avatar
I have to think about the millions upon millions of times these nuts were installed without the use of a torque wrench. Don't recall any issues being reported.
Old 06-02-2015, 07:41 AM   #8
scooder
Tight, but not red face tight.
Martin.
scooder is offline   Reply With Quote
Old 06-02-2015, 08:02 AM   #9
stangblue
stangblue's Avatar
Drums tight enough to get loose with tire iron. Rotors look up the Torque Specs.
Assumption is the mother of all foul-ups.
stangblue is offline   Reply With Quote
Old 06-02-2015, 08:20 AM   #10
Mart
Mart's Avatar
I use about 75 ft lbs. I tend to use a torque wrench purely because I have a really nice one I bought for next to nothing and get a kick out of using it.
Old 06-02-2015, 08:47 AM   #11
wbedwards
wbedwards's Avatar
I use a torque wrench on all my cars now. Had a tire dealer over tighten the nuts on a Miata one time and getting them off was quite an experience.
wbedwards
wbedwards is offline   Reply With Quote
Old 06-02-2015, 10:55 AM   #12
V8COOPMAN
V8COOPMAN's Avatar
Phil
NZ
Could you please explain WHY there would be "consideral difference" between front and rear wheel nut torque? DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-02-2015, 11:33 AM   #13
51 MERC-CT
51 MERC-CT's Avatar
Probably was referring to axle and spindle nut
Old 06-02-2015, 11:57 AM   #14
NealinCA
NealinCA's Avatar
Found this on the interwebs...
Lug Nut Torque Specs
Stud Torque Engagement
12mm 75 to 85 lb-ft. 7 Turns
14mm 85 to 95 lb-ft. 8 Turns
7/16" 70 to 80 lb-ft. 8 Turns
1/2" 75 to 85 lb-ft. 8 Turns (Early Ford)
9/16" 105 to 115 lb-ft. 8 Turns
5/8" 125 to 135 lb-ft. 8 Turns
NealinCA is offline   Reply With Quote
Old 06-02-2015, 12:13 PM   #15
Lawson Cox
Lawson Cox's Avatar
Wow. Talk about senseless worrying. Now let's discuss how wide open a cotter key be spread. Gimme a break.
Old 06-02-2015, 01:15 PM   #16
deuce_roadster
deuce_roadster's Avatar
The rear nut hub to axle IS important. I disagree with stangblu, When the drum is on properly, it should take a puller such as a KR Wilson to remove the drum. The axle drives the hub due to friction on the taper NOT the key. Improperly tightened rear axle nuts are the reason they break at the end of the keyway slot. Ford literature has this nut at around 200/ft lbs.
Wheel nut torque in lbs are less critical, but need to be tight enough they don't work free.
Old 06-02-2015, 01:42 PM   #17
Fibber Mcgee
Fibber Mcgee's Avatar
How far should a cotter key be spread? Do you spread both sides the same way or opposite? Do I magnaflux the old ones and reuse them or go with new ones?
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 06-02-2015, 02:30 PM   #18
36coupe
36coupe's Avatar
Wide fives?
Be consistent whether you go to 65 ft lbs or 105 ft lbs
I use a 85 ft lb torque limiter
36coupe is offline   Reply With Quote
Old 06-02-2015, 02:53 PM   #19
Phil Gillespie
My earlier comments on difference between front and rear were refering to nut to hub torques and not the wheel nuts. Brain did not process correctly.
The torque on front and rear wheels is the same and in region of 60 to 100ftlbs as per previous posts.
Phil NZ
Old 06-02-2015, 03:35 PM   #20
stangblue
stangblue's Avatar
What I thought we were talking about lug nuts or (wheel nuts). I'm going to put some pistachio nuts with bananas on my salad and go to bed early, plus its raining.
