Old 07-25-2025, 09:42 AM   #1
Stephenorf
Stephenorf's Avatar
Default 1959 1960 Mercury crossover parts
I have a 1959 Mercury Monterey and I'm trying to get the windshield wipers operational. The car did not come with a windshield wiper motor, so I purchased an aftermarket electric replacement from New Port Engineering. The problem is that the "Windshield Wiper Auxiliary Drive" will not lay flush against the firewall while orientated in the correct mounting position. When I got the car it was loosely bolted to the car with the bolts being partially cross threaded in.
I noticed the engineering number on the "Windshield Wiper Auxiliary Drive" is C0MB-17579....which seems like it was made for 1960.
I know there were a lot of major styling changes from 1959 to 1960, but I was wondering if the "Windshield Wiper Auxiliary Drive" for the 1960 Merc should work in a 1959 car. Many times the parts are interchangeable across years. I checked out the Merc catalogue and the part numbers are not the same:
PD9M-17579 for 1959
And C0MB-17579 for 1960
So the prefix changed from PB9M to C0MB....but did the actual part change enough to where they are not interchangeable?
Stephenorf is offline   Reply With Quote
Old 07-25-2025, 10:42 AM   #2
KULTULZ
KULTULZ's Avatar
Thumbs up Re: 1959 1960 Mercury crossover parts
Did your homework didn't you?
The 1959 and 1960 wiper motor and drive are different.
There was a major body/sheet metal redesign in 1960.
If the aftermarket motor is correct, you need the 59 MERC drive - PB9M 17579-A.
The 1959 wiper motor PN is B9MY 17508-A if you need it for reference.
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 07-25-2025, 01:50 PM   #3
Stephenorf
Stephenorf's Avatar
Default Re: 1959 1960 Mercury crossover parts
Thanks, that's what I was afraid of. I was hoping maybe the firewall where the drive hooked up maybe stayed the same. The PB9M is hard to find....1959 is a hard year for finding parts.
Incidentally, the motor in the car has an intake with engineering number with the prefix C0AE. It is a 312 and I do not know the history of the car/engine.
File Type: jpg 1959 Merc Intake Engineering Number b.jpg (160.7 KB, 28 views)
Old 07-25-2025, 04:25 PM   #4
KULTULZ
KULTULZ's Avatar
Post Re: 1959 1960 Mercury crossover parts
You are good. 1960 MERC used the 312 FYB 2V as the base engine.
- 1960 MERC - ENGINE CODE(S)
M - 430CI (MEL) 2V
N - 383CI (MEL) 2V
P - 312CI (FYB) 2V
Old 07-25-2025, 04:34 PM   #5
KULTULZ
KULTULZ's Avatar
Arrow Re: 1959 1960 Mercury crossover parts
START HERE - https://www.lincolnoldparts.com/
If no help or referral, get back and will give SALVAGE YARDS.
