Hi All,
Wondering if anyone has seen a reduction box like this? Cheers C ![]() Sent from my SM-F956B using Tapatalk |
Probably Australian creation.
No picture ?
Is it a reduction or an overdrive? Tim
Be easy enough to tell by turning input shaft.
TomC750 1949 8NV8 Ford tractor 1930 1 Ton White 1941 Mercury Sedan Coupe |
Definitely a reduction box, 2:1. Which would mean very low if you were in first gear, the reduction box engaged and then the differential in low as well! First one I've seen, i was hoping it was an overdrive! Cheers Corey Sent from my SM-F956B using Tapatalk |
Looks like you could turn it around and make it overdrive?????
