The transmission I found has no vin number on it or anywhere else are numbers that I can tell. The owner said he believes it is either a 32 or up to a 36. The car it is in is a 32.
Sure it's a Ford?
It could be a service part. No numbers on those. I have two NOS cases and neither has a number.
What is the number cast into the back, bottom of the case?
The part number of the case itself.
'32 has a unique top casting to mount the parking brake handle assembly to.
Don't never get rid of nuthin! |
Top covers interchange up to 36, only 32 is unique. Whats the number cast on the back of the case?
The Model B transmission has no number on it. The number will be on the flywheel housing.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
How about posting some pictures... there seems to be not enough clarification about shifter tops, and "numbers". The 32 year only has casting bosses in the shifter top for emergency brake, and yes other years had the emergency brake "mounted" to the shifter tip via a bracket. I regards the the numbers cas3 was asking for, they are at the bottom and would help determine the era of build. 18- or 48- or 78-7006 will be cast into case right below the lower cluster shaft. Is the shifter tower straight up and down, or at an angle?
#12 | |
![]() Quote:
