Old 10-18-2024, 02:25 PM   #1
Bruce Compton, Canada
Default Overdrive won't kick down
The overdrive in my 1949 Ford won't kick down. The engine shuts off when the gas pedal is pressed to the floor, but the overdrive won't disengage. The relay, governor, and solenoid contacts are perfect, and the kickdown switch is new. Everything has worked perfect until very recently. Any suggestions??
Bruce Compton, Canada is offline   Reply With Quote
Old 10-18-2024, 05:39 PM   #2
fordv8j
fordv8j's Avatar
Default Re: Overdrive won't kick down
Low voltage
fordv8j is offline   Reply With Quote
Old 10-19-2024, 10:40 AM   #3
flathead4rd
flathead4rd's Avatar
Did you check the 30 amp fuse on the relay mounted on the firewall?
flathead4rd is offline   Reply With Quote
Old 10-20-2024, 09:46 AM   #4
Bill OH
I would search the Chilton’s Motor Manual on Borg-Warner overdrive. Does the overdrive drop out when the speed drops below 25mph? I know if the circuit for the governor goes to ground without the action of the governor, the overdrive will stay locked in - Starts from a dead stop in overdrive and the car will not go back. I had them in a 53 Ford and 61 Ford - great transmission.
Bill OH is offline   Reply With Quote
Old 10-20-2024, 08:04 PM   #5
Don T
Don T's Avatar
Does the OD function correctly in all other ways other than the lack of a kickdown? The ford shop manual for the 49-51 has a diagnosis procedure on page 305 on this very issue?
Don T is offline   Reply With Quote
