Old 06-16-2024, 11:40 AM   #1
Keith
Default Fixed - Grabbing Front brake shoe
On 6-8-2024 I posted a problem I was having titled Front Brake Shoe Grabs.
Thank you for all of the suggestions.
To fix the problem after going through all of the suggestions I ended up installing P/N A-2051-F Brake Floater Kit from Snyder, it replaces P/N A-2051 Wedge Stud. I found the shoes on the passenger side were slightly off center and after installing the new part on both sides the brakes are now working fine with no grabbing when applying the brakes in soft and hard stops. I am able to lock all four wheels on payment with no pull in either direction. Keith
Keith
Keith is offline   Reply With Quote
Old 06-16-2024, 12:36 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Fixed - Grabbing Front brake shoe
Thanks for the update!!
www.whidbeymodelaclub.com
Old 06-17-2024, 08:34 AM   #3
Planojc
Planojc's Avatar
X2 on the update.
Planojc is offline   Reply With Quote
Old 06-16-2024, 03:11 PM   #4
nkaminar
nkaminar's Avatar
Keith, Excellent work. The pedal should be easier to push. Is it?
Old 06-17-2024, 08:25 AM   #5
Keith
Yes I have a nice high/firm pedal and do not need to apply a lot of pressure
Keith
