Old 04-07-2024, 06:30 PM   #1
meric42
meric42's Avatar
Default Rear end ckunking on left turn
I have a '57 Sunliner and rebuilt the 9" differential about two years ago using a good used ring and pinion along with all new bearings and clutch plates and have only put less than 200 miles on it. It has now developed a clunking when turning left. I have read that this can possibly be caused by a faulty axle bearing or needing friction modifier. I used specific LSD oil when I assembled and filled the Diff. I would be interested to hear the thoughts from those more experienced than myself to help solve this problem. Thanks in advance
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
https://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 04-07-2024, 06:50 PM   #2
KULTULZ
KULTULZ's Avatar
Arrow Re: Rear end ckunking on left turn
The rear has a clutch kit in it?
XL-3 Friction Modifier Additive - 4 oz.
https://www.amazon.com/Ford-XL-3-Fri.../dp/B000NU5LP6
What LSD LUBRICANT did you use for reference?
"Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'."
― Charlene Darling (Daughter of Briscoe Darling)
KULTULZ is offline   Reply With Quote
Old 04-07-2024, 07:27 PM   #3
meric42
meric42's Avatar
Default Re: Rear end ckunking on left turn
Originally Posted by KULTULZ View Post
The rear has a clutch kit in it? Yes
Yes new clutch kit when I rebuilt - I will need to check the container
Old 04-07-2024, 08:46 PM   #4
meric42
meric42's Avatar
This is the oil I used
Old 04-07-2024, 09:22 PM   #5
miker98038
miker98038's Avatar
I know different units require different additives, and my current ford experience is with an old Dana 44 in my bird. Probably different. But right after they outlawed whale oil I remember having problems with a posi unit. The answer was more additive, the new stuff wasn’t as good as the whale oil. It was just a couple ounces in that case.
You might check the specifics of what you used with the oem Ford (assuming it’s old ford parts) recommendations. If it’s aftermarket clutches, they may have a different spec.
miker98038 is offline   Reply With Quote
Old 04-08-2024, 01:27 AM   #6
KULTULZ
KULTULZ's Avatar
I checked the NULON WEBSITE and the fluid does not meet FORD SPEC EST-M2C118-A.
https://www.motorcraft.com/us/en_us/...modifiers.html
https://www.nulon.com.au/products/ge...fferential-oil
IMO ... ... add the FORD LUBRICANT, do a series of tight turns in a parking lot and see what happens. If no relief, the clutch pack break-away value can be checked on a lift with a break-away value torque wrench.
Where did you find the clutch unit? FORD did not use until the 1959 model year.
There is no one-fits-all lubricant and 20,000 mile oil changes, despite what the manufacturer tells you.
Old 04-08-2024, 10:51 PM   #7
meric42
meric42's Avatar
Thanks for all advice, I have ordered the Motorcraft friction modifier and will let you know how it works out.
Old 04-10-2024, 08:01 PM   #8
meric42
meric42's Avatar
[QUOTE=KULTULZ;2303201]
After getting my '57 home to NZ, I found that it had had a '59 292 Y-block and 2-speed auto installed, (with the engine mounts reversed) so nothing lined up with for the Transmission mount or drive shaft. Luckily I found a correct 3-speed auto, complete with drive shaft and all necessary parts from a '57 to swap into the Sunliner. I can only assume that the rear axle might have been changed at the same time by a previous owner?
The friction modifier has arrived today so this weekend I might have time to put it in, however the weather is not going to be fine enough to test it out. Hopefully I can do that the following weekend, subject to the weather being dry that is.
Old 04-10-2024, 08:04 PM   #9
meric42
meric42's Avatar
Here's a couple of pic's of the Sunliner, as purchased and from last weekend.
Old 04-11-2024, 06:36 AM   #10
KULTULZ
KULTULZ's Avatar
Thumbs up Re: Rear end ckunking on left turn
Isn't that something? FORD began offering the clutch rear end in 1959 so that would explain it.
The SUNLINER is nice and is going to make a beautiful driver. I see it has a BIRD ACL. Nice touch. I have always wondered why guys did not use that ACL when dressing one out, especially with the BIRD ALUM ROCKER COVERS.
Hope the FRICTION MODIFIER works out for you ...
BTW - Are MOTORCRAFT LUBRICANTS readily available down there? I have exchanged with several AU guys that say it is hard to find even at a dealer?
Old 04-09-2024, 02:32 PM   #11
Gene F
Gene F's Avatar
It's the easiest, so good idea to give it a try. Honestly, the first thing I thought of just reading the title was the lube.
Old 04-09-2024, 06:42 PM   #12
Ford Freak
Me too!
1952 Ford F1
!956 Fairlane Club Sedan
1965 Falcon Sprint
2007 Mustang GT
Ford Freak is offline   Reply With Quote
Old 04-21-2024, 04:06 PM   #13
meric42
meric42's Avatar
***** UPDATE *****
Thanks to all who responded, I sourced the Motorcraft fiction modifier, put it in the diff. went for a drive on Saturday, and voila, it would appear that my clunking diff. has been cured, thanks to all for your help, much appreciated.
Old 04-21-2024, 06:28 PM   #14
1942deluxe
1942deluxe's Avatar
Meric, good deal! They changed the friction modifier formula at some point but it still works good. If you got the original on your hands you couldn't get the smell out for weeks! Ford techs would ask parts guy for a bottle of "the stinky stuff".
Old 04-22-2024, 09:11 PM   #15
meric42
meric42's Avatar
It sure does stink
Old 04-24-2024, 05:16 PM   #16
Gene F
Gene F's Avatar
Oh and I'm sure it was changed for the better...yeah right!
