Old 02-08-2024, 06:44 AM   #1
Martinbuilt
Default Quick measurement needed, '29 Coupe or Tudor
I'm piecing together a sport coupe.
My subrails were torch cut in the front, so I need to make some repairs.
If you have one of these cars, can you measure the door opening?
Distance between the A and B pillars. At the sill, and maybe at the latch?
Thanks
Martinbuilt is offline   Reply With Quote
Old 02-08-2024, 10:28 AM   #2
wrndln
Default Re: Quick measurement needed, '29 Coupe or Tudor
I have a 28 special coupe that is identical to all 29 coupes as far as the door openings are concerned. The measurement from the A pillar to the B pillar at the bottom is 27 1/2". The measurement just above the latch pocket is 28 1/16". Hope this helps.
Rusty Nelson
Old 02-08-2024, 12:47 PM   #3
Martinbuilt
Thanks very much. I would not have guessed those two measurements to be different.
I'll have to try and cobble it all together and see if I can hang the doors..
