10-26-2023, 12:17 AM | #1 |
Mello Tones on a Y block
This what her new exh. system sounds like. Nice little rumble when I get her dialed in.
https://youtube.com/shorts/aDW2ewwu2...eyRpoedEHvTrB- Mike
10-26-2023, 06:46 PM | #2 |
Re: Mello Tones on a Y block
Sounds good. Glad to see you’re making progress.
10-26-2023, 08:50 PM | #3 |
What mufflers did you use? Size? How loud when you're on it?
10-27-2023, 12:08 PM | #4 |
Just bought Mello Tones-22" (the longest ones) as I didn't want the crackly sound of the short ones. Just on idle for now, I will post a second video when I get the engine sorted out.
10-27-2023, 05:46 PM | #5 |
My streetrod has Flowmasters, and it seems too loud for me. The car has a 373:1 gear, so maybe that has something to do with it. My last streetrod had Cherry Bombs on it, which were not too bad. I put a set of MagnaFlows on my 57 Skyliner with a Y-block. Pretty normal sounding...untill you take off from a light and floor it. Then you get that Y-block sound I have always heard about. Took my Dad for a ride, and he sure noticed! I'd buy MagnaFlow again!
10-27-2023, 06:14 PM | #6 |
What size are your Magnaflows? |
10-27-2023, 07:06 PM | #7 |
The physical size is the same as factory. Factory size pipe too. Factory exhaust manifolds.
Borla - I always like those. Especially with the large tubes. But the price!!!! |
10-27-2023, 08:43 PM | #8 |
Space is limited on my 55 Tbird; the Borlas are pretty close to the same size as OEM, but 2 1/4 in and out vs. 2 in and 1 3/4 out for OEM. I also bought their resonators, which were actually more expensive than the mufflers. The resonators, in theory, deepen the tone and reduce/eliminate drone. Although 56-57 Tbird resonators are located towards the rear, after the mufflers, most recommend putting resonators before the mufflers.
10-28-2023, 09:24 AM | #9 |
I've had Flowmasters and others, and they've been good, but I love the sound of the Mello Tones.
10-28-2023, 11:16 AM | #10 |
https://youtube.com/shorts/oxf2KFW0X...xtNYpo4zvMtR-l
I have the same set of glass packs that I installed way back in 1992. I love the sound, but I know they are not the greatest on performance. Back then I also replaced the rear pipes - believe they are 1.75" exit. Everything is still as solid as it can be, but with my upgrade to a a set of true headers last year I do want to increase the flow and size of the pipes. I did buy a set of Summit's performance mufflers but I believe they are a Flowmasters copy. I would like to go with at least a 2" pipe out the rear.
Lancaster, California Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan! |
11-07-2023, 03:41 AM | #11 |
Back in the day, we always put a balance tube between the two pipes, ahead of the mufflers. It made the Y-block sound much smoother. Product of the firing order I guess, as they always sound like the spark is retarded without the tube.
I like 36" glasspacks, as Flowmasters sound like a trash truck to me. I will be removing them from my 55 T-Bird. YMMV |
11-07-2023, 05:24 PM | #12 |
I have considered putting an H-pipe on my 55 Tbird for that reason. I've been communicating with an owner of a 57 E-code Tbird who did the same. Ted Eaton, however, said that neither an H nor X-pipe will increase Y-block performance.
Most Flowmasters that I've heard on vehicles without cats have a metallic sound, similar to marbles rattling inside a tin can. |
11-17-2023, 11:57 AM | #13 |
Sounds good, I think my wagon has the same, but very old ones. Those sound new and crispy, Idle sounds good too.
FYI I think there is an image on wagon exhaust routing for the tips. There a certain angle and length, which you can do with the chrome extension, so exhaust doesnt come into the cabin if the rear window is up . |
11-17-2023, 05:25 PM | #14 |
If the window is up or down. Carbon monoxide collects at the rear of the car in motion and will enter the cabin.
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
11-17-2023, 12:25 PM | #15 |
Yep, I had him replicate the location of the original single exhaust. I will put angled tips on eventually. Dress her up a bit. But right now I am doing floor pans.
11-17-2023, 05:23 PM | #16 |
