Thermostats on As are installed in the upper radiator hose? Thanks.
Not all, Vintage Precision has a really nice tstat setup. Check it out.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" ![]() |
That does look good. But I've already got the water outlet gooseneck tapped for the water temp sensor.
#4 | |
![]() Quote:
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
Yes, upper hose. Often you will find that the thermostat migrates to the top of the hose, which will alter its behavior. People use various strategies to mitigate this. You can cut a section of lower hose, which is narrower, and put it in the upper hose above the thermostat. You can also just add a hose clamp, but some folks consider this unsightly, hence the lower hose workaround.
I went to the hardware store and found a couple plastic pipe fittings that fit snugly, the two in tandem hold the thermostat at the water outlet neck.
If I put in a section of lower hose into the upper hose to hold the thermostat in place can it be a short section or should it be the length of the upper hose? There must be a fairly strong force of water going through.
Some people say drill a couple of small house in the thermostat so that there is always some coolant getting through. Should I? I'm also putting in a new Brassworks radiator. I will flush out the block first. Some folks say stretch an old sock over the upper radiator water inlet before attaching the hose to prevent crude from getting into the radiator. Is this a good idea? |
1. 1-2” of lower hose is probably fine.
2. Current thermostats come with the holes already drilled. 3. If you’re serious about protecting the radiator, I suggest a Gano coolant filter, not a sock. |
Is there a market for a Gano Filter/Thermostat combined device? I can't see that it would be difficult but setup costs might be too high.
I sometimes wonder what happened to the people who asked me for directions. Even at my age, I still like to look at a young, attractive woman but I can't really remember why. |
I took a look at the Gano coolant filter. What a great idea! Never knew about it. I will get one. Thanks!
After years of chasing the thermostat around the upper hose I made this fitting. It simply fits in the water outlet neck and is held in place with JB Weld. So far it has worked quite well.
IMG_1988.jpg |
#13 | |
![]() Quote:
Wello, It has been my experience that glycol based antifreeze will attack the two component adhesive.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
#14 |
I used a black zip-tie above the thermostat. So far, keeping it in place and it blends in with the black hose. It's not too noticeable, but it's a truck and I'm not concerned about points.
Stickshift 1915 Model T touring 1931 Ford Model AA Flatbed |
#15 |
I use the Vintage Precision unit and could not be happier. A bit pricey, yes, but a first-class device. The sensor on my water temp gage was long so I had to add in VP’s extender fitting, I think that should be part of the normal package, not an add-on. I use the fitting in the upper radiator hose for my coolant heater.
JayJay
#16 |
Lots of great info! Ford Barn has been a real asset. Thanks everyone!
#17 |
Can I ask a question. Who cares if it ends up at the top end of the hose, up against the radiator neck. I mean why do we care? It still will slow down the water.
#18 | |
![]() Quote:
The small holes in the thermostat is to let air out of the system when you refill it. |
#19 |
You need a plug in the side your distributor, helps keep dirt and moisture out
#20 | |
![]() Quote:
