Old 05-26-2023, 07:34 PM   #1
Big g
Default Dash light
The instrument light on the dash of my 29 Tudor has never functioned since I purchased the car. Never bothered me before but now I would really like it to work. My silly issues is, I do not know how to turn it on. Anyone??
Big g is offline   Reply With Quote
Old 05-26-2023, 07:36 PM   #2
Bill G
Bill G's Avatar
Default Re: Dash light
Push and turn clockwise about 1/8 of a turn. Just pushing will turn it on. It will turn off when released unless turned clockwise. Turn counter-clockwise to turn it back off. It takes a #63 6-volt bulb if you are still running 6 volts.
Old 05-26-2023, 07:44 PM   #3
Big g
Thank you so much.I just installed a new wiring harness and have new ambition to make everything work. Thanks
Old 05-28-2023, 01:49 PM   #4
Ted Duke
If you put an LED bulb in it you will have more light, less current draw and it WON'T burn your fingers.
Ted Duke is offline   Reply With Quote
Old 05-28-2023, 02:12 PM   #5
nkaminar
nkaminar's Avatar
If you have a modern ignition switch you can wire the light to turn on only with the ignition on. So if forget to turn the light off it will not drain your battery.
Old 05-29-2023, 12:28 PM   #6
stickshift
stickshift's Avatar
That's exactly what I did. When I first got my truck, the dash light was burned out. I replaced the bulb and it was on all the time. There was no on/off switch lever like I've seen online. I found a spare spade connector on the rotary switch for the lights that went to the tail lights. I ran the wire into the cab through the box on the fire wall and spliced it to the pigtail for the dash light. Now the dash light is on whenever the lights are on in any position.
Stickshift
1915 Model T touring
1931 Ford Model AA Flatbed
stickshift is offline   Reply With Quote
Old 05-29-2023, 03:00 PM   #7
Gene F
Gene F's Avatar
I had a aviation grade light bulb in there. It was the replacement for the #63. It had a heavy duty filament, but it finally burned out. I got it at NAPA. Wish I still had that part number, because the light I have now is not as much candlepower.
Old 05-30-2023, 09:44 AM   #8
katy
katy's Avatar
Does the bulb not have a number on it? Possibly a #81, 6 CP compared to a #63, 3 CP.
Old 11-01-2024, 01:35 PM   #9
veteran#94
i have the stock dash light but can not find a bulb. the socket takes a single contact w/offset pins bulb.
veteran#94 is offline   Reply With Quote
Old 11-01-2024, 10:46 PM   #10
katy
katy's Avatar
You can use a bulb with equidistant (non-offset) pins, just file one pin off.
Bindar, dundat.
Old 11-02-2024, 08:23 AM   #11
Badpuppy
The indexed bayonet base is used only for double contact bulbs. Maybe somebody replaced the socket and swapped the contact disc too.
I would use the stock bulb and file off one pin, as others have suggested.
Old 11-01-2024, 02:40 PM   #12
Chuck Dempsey
Chuck Dempsey's Avatar
Vet #94 - is this not it? https://www.snydersantiqueauto.com/p...d=976629&cat=0
Chuck Dempsey is offline   Reply With Quote
Old 11-01-2024, 05:36 PM   #13
veteran#94
i can't see if that has offset pins.
Old 11-01-2024, 05:41 PM   #14
veteran#94
i sent a message to snyders to verify if it has offset pins.
Old 11-01-2024, 05:48 PM   #15
Chuck Dempsey
Good idea. The description should tell you. Some do, some don't....
Old 11-02-2024, 03:12 AM   #16
German guy
German guy's Avatar
It is a pain in the posterior. To turn it on, simply push it in as you would a cigarette lighter in a modern car. Pull it out slightly and it should go off. The problem is that the fixture gets worn and comes on every time you hit a bump in the road...or temperature causes metal expansion to have it come on while parked...killing the battery. Mine does NOT have offset pins...they are two pins at equal distance from the bottom.
German guy is offline   Reply With Quote
Old 11-02-2024, 05:12 AM   #17
nkaminar
nkaminar's Avatar
German Guy, The LED does not get hot like the incandescent bulb and will not drain your battery (as fast) if you forget and leave it on. Sorry, I don't have a part number but do a search for the equivalent LED. See post #5.
Old 11-02-2024, 06:12 AM   #18
TomInCologne
TomInCologne's Avatar
I leave it in the 'on'-position all the time, it being lit is my reminder that i have not turned off the main switch when parked... As i have an LED (yellow), leaving it on does not heat things up too much.
TomInCologne is offline   Reply With Quote
Old 11-03-2024, 10:18 AM   #19
Fullraceflathead
Fullraceflathead's Avatar
Replacing the original bulb with a much brighter LED sounds like an excellent idea to me I need to change my mind to that!!!
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 11-03-2024, 12:08 PM   #20
The Master Cylinder
The Master Cylinder's Avatar
I have never seen a single fiiment bulb with offset pins. I see no use to do that. I am using a LED in my Town Sedan, burned my fingers one to many times using an regular bulb!
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
