Old 03-18-2023, 09:07 AM   #1
whatdoyouwant
Default 48 merc shocks
I have questions about the front shocks on my 48 mercury. Fully extended they are 18-1/2 inches, closed they are 11-1/4 inches. These measurements are longer than the after market shocks that are advertised. Questions about removal. The top connection is simple, just take the nut off and pull the shock from the stud welded on the bracket. The bottom of the shock connect to part of the suspension. I take the nut off and nothing moves. Is the stud part of the shock. I can't see any thing that looks like the head of a bolt on the other side of the shock. Is the lower bolt threaded into the suspension? Any help would be great
al
whatdoyouwant is online now   Reply With Quote
Old 03-18-2023, 09:15 AM   #2
Als48
Default Re: 48 merc shocks
You should be able to drive the bolt out of the perch bolt attachment point after removing the nut.
Als48 is offline   Reply With Quote
Old 03-18-2023, 07:24 PM   #3
TJ
TJ's Avatar
The old rubber may be stuck to the shock stud. Spray some WD40- on the rubber bushing to see it helps get it to move. Once the upper is loose pull the shock downward to see if the rubber breaks loose from the stud.
Old 03-19-2023, 08:36 AM   #4
whatdoyouwant
I was afraid to beat on the stud too much because I didn't want to break anything. I took a grinder and split the bottom of the shock mount to expose the stud. I then took a pipe wrench and turned the stud a little and it came right out. I found that it was tapered just like a tie rod end. After much research I found that Monroe 32207 shocks will work.
see photo
