I am working on a 36 Pickup. Does the wood subfloor that shows from underneath get painted or is it left bare and only the steel subframe painted? Art
Good question. I painted mine. I have seen some evidence of what appeared to be "overspray" on the underside, but that really doesn't make sense.
If not painted with a color, urethane it for preservation.
If it is hardwood, which it should be, just leave it bare wood.
The wood was treated with stain. The best choice is Minwax Ebony.
One would think............that Ford would NOT have painted the entire wood bottom -- waste of paint, so overspray would be the logical choice. That is what I did with mine. |
#6 | |
Occam's razor. The simplest answer is usually correct. |
I had to look up the definition of "Occam's razor". I learned something new today.
Thanks!
Coming on 52 years as a professional woodworker with many repair/restoration projects involving older wood structures, I would definately seal or saturate any hardwood under a vehicle. Red oak, maple, birch and many other hardwoods are quite prone to rot and bug infestation. Bed wood was almost always a softwood. Not soft like white pine, cedar or redwood, but forms of hard southern pine (pitch pine, yellow pine, loblolly), various species of fir etc. White oak and locust would be good choices for new structural under cab members. In old New England quarried granite fence posts were not uncommon. It was said that if one were to set a granite post and a locust post alongside each other, the granite one would outlast the locust one by a year.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
Lawson...........that is not what Ford did. The wood was stained. The under the cab wood, the under the box blocks, the wood under the box -- all stained with something. The closest reproduction stain is Minwax Ebony -- this is information from the late Roy Nacewicz, and I trust his research.
#10 | |
![]() Quote:
Kube did a restoration thread here on a 39ish pickup. I looked for it. Covered what he did. Very nice restoration.
On a personal note. If it's not points. paint or treat the wood. My 38 with a wood subfloor under sheetmetal bed (last yr) was raw wood as best I could tell after 80 yrs. Suppose the best treatment back then was either hardwood, paint/stain, or creosote. Best I can tell is it was hardwood. Last edited by Tinker; 08-26-2022 at 10:02 PM. |
#12 | |
![]() Quote:
![]() Ford did in fact treat the wood. If I recall correctly (oh oh) they used a mixture of "scrap" oils. The end result was wood that was blackened. MinWax, Ebony, as posted earlier is a very good product to simulate the original finish. I use two coats, occasionally three, to get the wood dark enough to replicate the original. The two photos I'd attached are from that '40. It is, I'd think it's obvious, that it was "over restored". Regardless, the wood was not directly painted.
#13 | |
![]() Quote:
I get it. Some of us are more interested in the details and restoration. Some driving around in circles. Makes sense to me. The theory is based on information. Now days we base information on hearsay. Pretty sure you are someone I trust for ford information. Last edited by Tinker; 08-28-2022 at 10:42 PM. |
#14 |
I tend to get bored with them after the project part is over. I think I've only driven the woodie twice this summer. Most of my spare time is spent on whatever current project is in the shop. For years I loved to build and rebuild boats. Then they'd sit in the water or on a trailer while I started something else. A guy could fall overboard or sink out there for God's sake...
#15 |
see other post.
Last edited by highbeams; 08-29-2022 at 12:17 AM. Reason: erase this post; keep the other one; as they are twin posts. |
#16 | |
![]() Quote:
#17 |
#18 |
When I restored my 1950 F-1, I used Thomson water seal on the new wood.
#19 |
Not beng BBC a stock restoration guy, I primed and painted the CT under side of my non-stock 40 pickup using Spray paint and Satin black was the top coat. Just in case there are C others here on the Barn building “outside the box” Ford pickups…….
#20 |
Just as a point of reference, in the mid-1930's at least, Ford painted, in the same body color, the entire big truck flatbed assembly after it was fully assembled. This included the underside metal ribs and wood floor. I know this is not the same issue you guys are discussing with pickups, but I just wanted to chime in that Ford did, for some models at least, paint the underside of the bed. The body color painting includes not only all of the steel framing parts, but the wood and hardware too as it was done after being fully assembled. The racks were also individually painted body color, fully assembled with wood slats riveted to metal stakes.
My opinion comes from studying lots of factory photos of truck beds at the Ford Archives as well as looking at several original survivor trucks. Thanks for this discussion as I learned something about pickup beds that I didn't know. |
