Old 02-16-2022, 01:09 AM   #1
tomcarman
tomcarman's Avatar
Default Hair splitting for AnthonyG?
A bit off topic but relevant nonetheless. AnthonyG may know the correct answer to this being he studied metallurgy at Temple. I have been admonished several times on using the term "angle iron" by structural engineers. It was pointed out to me that though it is in fact angled it is not iron but steel. There is a difference as steel is an alloy. Perhaps a clarification is in order? Recently, and I don't recall which member has been a self-appointed hairsplitter regarding these sorts of things. LOL. This post is intended to be in good humor regarding proper terminology. For those who do wood work is it a lag bolt or a lag screw? If it's a lag bolt then why is it shaped like a screw and why is a machine screw shaped like a bolt? Just wondering.
Tom
tomcarman is offline   Reply With Quote
Old 02-16-2022, 02:14 AM   #2
cas3
Default Re: Hair splitting for AnthonyG?
there is "formed" angle iron, as in formed in a brake, nice round edge, and regular angle iron, square corner, not sure how its made, but thats enough for me
Old 02-16-2022, 02:19 AM   #3
T Scott
It's kind of like, is it an engine or is it a motor? I was told at one time that an engine was either steam or combustion powered and a motor was electric. Then again, I can't say that I ever heard of a Harley Davidson "engine cycle".
T Scott is offline   Reply With Quote
Old 02-16-2022, 02:39 AM   #4
ford38v8
ford38v8's Avatar
The term “lag bolt” is indeed a misnomer. It is a “lag screw”, both names refer to the same connector. I’ll go you one more… you referenced “wood work” which more commonly would refer to the finishing of furniture or cabinetry, as opposed to carpentry, for which lag screws are in frequent use. As for iron and steel, I suppose a housewife with a steam iron could be called an iron worker, while a steel worker builds skyscrapers? … And then there are motorboats powered by flathead V8s!
Alan
Old 02-16-2022, 03:12 AM   #5
V8COOPMAN
V8COOPMAN's Avatar
Tom
Kind'a sorta like: Why do we drive on a PARKWAY, yet we park on a DRIVEWAY?
DD
Click Links Below __
T5 W/TORQUE TUBE
Old 02-18-2022, 08:55 PM   #6
Craig CT
Craig CT's Avatar
DD
Hi DD; I heard George Carlin use that line in one of his routines years ago, Craig.
" When I was a boy of fourteen, my father was so ignorant I could hardly stand to have the old man around. But when I got to be twenty-one, I was astonished at how much he had learned " Mark Twain.
Craig CT is offline   Reply With Quote
Old 02-18-2022, 09:32 PM   #7
MGG
MGG's Avatar
I was told by a mechanical engineer friend of mine that an engine takes a fuel and produces mechanical power from it while a motor takes one form of power (electrical) and changes it into another form of power (mechanical).
MGG is offline   Reply With Quote
Old 02-16-2022, 10:14 AM   #8
flatford8
flatford8's Avatar
I used to work with a guy that called both channel iron and angle iron “changle”. He new what he was talking about but nobody else did……Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 02-16-2022, 10:21 AM   #9
Tim Ayers
Greenland is covered in ice. Iceland is not. Discuss....
Old 02-16-2022, 11:06 AM   #10
GB SISSON
GB SISSON's Avatar
'Angle iron' is like 'cinder blocks'. Just terms left over from an earlier age by old guys that won't change. In the 70's I worked in Southwest Harbor Maine, and the guys called the brick thing sticking out of the roof a 'chimbley' and the gas pedal was always an 'exhilerator'. Oh and a pair of channelocks was a pair of 'waterpump pliers'. I still miss those guys.
Old 02-16-2022, 11:25 AM   #11
Tim Ayers
I'd bet these same guys called underwear drawls and a creek a crick.
Old 02-16-2022, 11:36 AM   #12
Ol' Ron
Ol' Ron's Avatar
What kind of iron would you call "bed angle". Un drillable iron????
Old 02-16-2022, 11:40 AM   #13
Tim Ayers
I call it free transmission stands.
Old 02-16-2022, 11:41 AM   #14
V8COOPMAN
V8COOPMAN's Avatar
It surely must be called "squeak-inducing" iron! DD
T5 W/TORQUE TUBE
Old 02-16-2022, 11:55 AM   #15
tubman
tubman's Avatar
Wow! It sure is nice to know the real name for water pump pliers.
But isn't it more like calling all copy machines "Xerox machines"?
Old 02-17-2022, 11:32 PM   #16
fordor41
fordor41's Avatar
As I remember, water pump pliers have curved jaws, channel lock type pliers have straight jaws.
fordor41 is offline   Reply With Quote
Old 02-18-2022, 12:24 AM   #17
bbrocksr
Channel lock is a brand name for tongue and groove pliers like Crescent is a brand name for an adjustable wrench.
Bill
bbrocksr is offline   Reply With Quote
Old 02-18-2022, 11:23 PM   #18
fordor41
fordor41's Avatar
Originally Posted by bbrocksr View Post
A cap screw has has the same size threads all the way, It becomes a bolt when used with a nut.
8BA heads are held on with cap screws.
If it screws into a threaded hole in a casting it is a cap screw.
If the same fastener is used with a nut it becomes a bolt and nut.
To most mechanics they are all bolts,
Bill
Bill
Channel lock "type" pliers
Old 02-16-2022, 12:12 PM   #19
Cool Hand Lurker
Cool Hand Lurker's Avatar
Wow, I am really glad I read this. I always thought it was spelled 'steal' angle. Been arrested three times right in my shop working with angle 'arn....
Cool Hand Lurker is offline   Reply With Quote
Old 02-16-2022, 12:17 PM   #20
37 truck
A sledge hammer is a Double Jack, scaffolding is staging, wire cutters are dikes, and slip joint pliers are water pump pliers.... a pry bar is a crow bar?
37 truck is offline   Reply With Quote
