Since you guys were so good on my w/s reg. I hope you can tell me the years these are.
The black one is a 40. Seems that it came off my old coupe. The grey one was picked up somewhere..It has different stamping and factory spot welded mounting tabs. Thanks! |
The gray one is the first design used in 1939 on the Deluxe models. Those small brackets were eliminated in late ('39) production. While the brackets were eliminated, MANY of the panels were installed had the holes in the fender panel.
Neither of the afore-mentioned panels, should be seen on a concourse '40.
Thank you, Kube!! for the EXPERT analysis.
You're very welcome. I should have added the fact that they DO interchange if you'd like to do that.
Thanks again! |
