Old 08-18-2021, 10:35 PM   #1
jerryt
Default What size
I am trying to find what 12 volt battery to put in my 1926 ford roadster truck. Any ideas?
Thanks
Jerry
jerryt is offline   Reply With Quote
Old 08-18-2021, 11:23 PM   #2
redmodelt
redmodelt's Avatar
Default Re: What size
Does it mount in the stock location? If not, then you would need to measure the space and check online to find out what size would fit. If it mounts in the stock location, under the bed behind the seat, you would need one that is the same size as group 1.
Old 08-19-2021, 12:27 AM   #3
jerryt
Battery mounts in passenger side floor.
Thanks
Jerry
Old 08-20-2021, 10:59 AM   #4
rotorwrench
rotorwrench's Avatar
Here is a link to BCI group dimensions. https://www.jegs.com/Sizecharts/bcigroup.html
Measure the battery container and go from there.
Old 08-26-2021, 10:39 AM   #5
RAJO special
Yep, I believe it's a group 1
RAJO special is offline   Reply With Quote
Old 08-26-2021, 06:21 PM   #6
redmodelt
redmodelt's Avatar
I just realized you said Passenger side floor (right side of car?), that is not the normal spot. Normally it would be left side under the floor just behind the front seat (ALL body types when mounted on T car frame) So I am going to say, you will need to measure the box it will fit into.
