I'd like to polish my '35 Coupe before I wax it. Gently.
I'd appreciate any advice? Small electric rotary polisher? Polish brand? Any examples to follow? Thank you. Jim Hauschultz |
Clay bar by-hand. I rub it while wetting with the quick detailer. Then I have something I feel like putting a shine onto. That I also apply by hand and using the directions on the container. I use Meguiar's products and a lot of patience and breaks.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
I wash the car first, THEN as VeryTangled said, clay bar the whole car, then I rinse the car again with a very clean bucket, water and a very clean cotton cloth. Then shammy the car off then take air hose and blow the car of any hidden water, then wax it!!! Be sure to set your wax after you wipe it off with a mist of distilled water and wipe clean with a microfiber!!!
Thank you all. Experience is the best education, and now I have some confidence.
Of course you have to realize that the type of paint that is on the vehicle should dictate what method is used to polish it, not what others have done to their finishes.
I just watched a video on claying the paint,I’ve never seen that done before, couple questions.
Do you have to use the speed shine, or will slightly soapy water work? Will this work well on 60 year old laquer paint? My go to has always been rubbing compound. Thanks |
#8 | |
![]() Quote:
I think the important part is not to use the clay bar dry. Soapy water shouldn't be any problem.
I use both rubbing compound or polishing compound...depending on the painted area. Polishing compound is more gentle.
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
I've used "Mothers" products for a number of years now. They have the full range of washing cleaning, cutting, polishing and detailing products. Always by hand and never a machine.
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
