Hi; I have a 1930, 6 volt positive ground. If I leave the fuse in after shutting off the car, I am experiencing about .2 volt drop in voltage at the battery over about 6 hours. Is that normal?
If not; Do I need to just start disconnecting wires from the horn, lights etc. to find the drain? Or, can I check various wires with a clamp amp meter to determine the drain or will all of the wires show an amperage reading if there is a drain? Thanks for your help. Mike |
Mike, do you have a generator or alternator? Did you disconnect the wire from the alt/gen and see if your draw is eliminated? A self-exciting regulator in the alternator does have a draw.
Yes, just begin eliminating circuits. The original type ignition switch can also see leakage as the ignition coil stays 'hot' all the time. You can remove a circuit and then use a test light in that circuit to see if there is a draw as it will dimly illuminate if there is a draw downstream. |
Thanks Brent. Yes, I have an alternator and I checked it. It shows a draw of .9 amps so I believe that would be the reason the battery draws down if I leave power to the system. I will just need to make sure I cut the power to the car when I shut it off for a period of time.
Thanks, Mike |
#4 | |
![]() Quote:
https://www.ebay.com/itm/10SI-Delco-...3587816?_ul=IL |
#5 | |
![]() Quote:
Thats a draw that should be addressed. And, yep, its an easy fix and parts should be available. |
Alternators have a parasitic draw, its just in their nature.
So, a heavy main disconnect switch that is easily accessible may be a good addition. |
I will do that. Thanks for the help.
Mike |
Alternators with a bad diode can have a parasitic draw but a well functioning unit will have no draw at all. It is not in their nature to have a problem like that but it can happen over time with electrical spikes or excessive jumping of a worn out battery. I really can't speak to the reliability of the conversion parts. I only tried an alternator once before going back to a generator on my old 29 Ford. The 10si is very reliable using 12-volt negative ground (normal) components in a 3-wire configuration.
The kits used to convert a Delco 10si to 6-volt have a new diode bridge & regulator plus all the parts to overhaul one of these units. These parts and the polarity jumper are all thats needed in a conversion. |
#10 | |
![]() Quote:
Hi; I called Nu-Rex and asked them about the draw. There is a draw on the alternators. There is always a small draw when the Battery is connected. 1 - 2 amps is not uncommon but they said it should not cause a significant voltage loss at the battery over time.
Mike |
#13 | |
![]() Quote:
Well, Nu-Rex is right. But I think that amount is a bit high, but, regardless they draw. As mentioned, a good shut-off in a convenient location is a good thing. |
#14 |
#15 | |
![]() Quote:
A brand new alternator will have a minimal draw. Diodes do not resist backflow 100% nor do they conduct current 100%. Bill P S I hate to agree with Brent but he's right. |
#16 |
#17 |
This may be unrelated, but it is normal for a battery to loose a little voltage when sitting after being charged.
When I am away from my car for more than a week I will disconnect the battery with the main switch and put a battery maintainer on the battery.
#18 |
I've worked on many old GM vehicles that had the 10si and repaired dome light switches that showed a current draw but there was never a draw after the repair completion. Now I'm not a fan of the 6-volt conversions so that's why I can't vouch for them. I converted my Ford 850 to 12-volt so I could get the reliability and there has not been a parasitic draw problem with it yet. I use all three wires and a warning light. After I shut it down the ammeter is at zero.
#19 |
I guess one could mount an original style generator cutout on top of the alternator. Once the contacts are open, there is no current flow.
#20 |
