Anyone use this seal successfully ?
I use the rope seal successfully.
#4 | |
![]() Quote:
I know, I answered because over the years I've read mixed results about this seal. |
The modern shaft seal ("Simmering") can only be fitted if the entire front housing and the oil pan has been removed.
I also used the ropes mentioned by Patrick. When installed correctly, they provide a very good seal. There is only a slight oil mist on my car, always less than 1 drop. (The oiling out is much worse at the back of the crankshaft!)
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
"The more things change, the more they stay the same." |
I have used one for 28,000 miles in my Tudor. No leak yet. Put it in with black rtv.
John
Welcome each day |
John,
please tell me what is "black RTV"?
Permatex Ultra Black
#11 | |
![]() Quote:
I have used in at least 10 engines with great success. Now I have one that leaks, I am pulling the oil pan and replacing the seal later this month. I think the pan is the culprit in this leak. That seal that failed immediately and I am not looking forward to all the work to change it, as it requires lifting the engine after pulling the radiator etc. to remove the pulley. I am replacing it with another modern seal.
#13 |
May want to look into the Stipes Specialty Motor Cams modern seal if using one. The original asbestos soaked ropes were reliable but no longer available. A smooth unpainted pulley shaft is essential.
#14 |
It is imperative that the surface of the pulley that the seal rides on is absolutely smooth.
This is especially true when using a new pulley. The fine machining marks on the pulley will ware out the lip of the seal and cause it to fail prematurely. I polish this surface when I assemble an engine. Chris W. |
#15 | |
![]() Quote:
http://www.specialtymotorcams.com/de...ront-seals-011 Last edited by Y-Blockhead; 07-12-2021 at 09:43 AM. |
#16 |
I helped a friend put one in. He was told to not us rtv when installing it and it imediately leaked. We removed the seal and filled top and bottom with channel with rtv, pushed seal into place and it quit leaking. We used paper pan gaskets with a smear of rtv on the pan side only and torqued the bolts evenly, just tight. So far so good.
#17 |
Hi Rick,
Look into the Stipe modern front seal. It uses an aluminum housing to hold the shape. |
#18 | |
![]() Quote:
Thanks for your input regarding this modern seal. For your info, my B engine is out of car and on a stand. That made it easy to fit up the seal. Yes it did take consentration to get the seal onto crank with pully, front cover and pan.. ALL at same time. Do not think that this can be successfully done with engine in car! At least I would not attempt it. Haven’t started engine yet, to see any leaks or not. Thanks for ALL your practical hands on input / experience regarding this neoprene modern seal. |
#19 |
I’ve used over 300 of them on our engines. Had a couple leak, all the rest have not. Must use a new or very smooth pulley and be sure it Is centered and held in place with Ultra black.
#20 |
Any preference or results for a 1 piece vs. a 2 piece pulley ? Are the threaded type 2 piece pulleys acceptable as well?
