Old 10-28-2020, 12:58 PM   #1
melisahe
melisahe's Avatar
Default Ford T8D-1 shift pattern
can't get trans into reverse- is reverse over to the right and up or is it over to the right and down? Does it help if engine is running? Thanks Mike
melisahe is offline   Reply With Quote
Old 10-28-2020, 01:06 PM   #2
Ross F-1
Ross F-1's Avatar
Default Re: Ford T8D-1 shift pattern
Is that the non-synchro truck 4-sp? If so,
1-3
2-4-R
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 10-28-2020, 01:25 PM   #3
melisahe
melisahe's Avatar
Thanks, that is it. still won't go to reverse.
Old 10-28-2020, 05:01 PM   #4
raybee
Are you pushing down on the reverse lockout lever?
raybee is offline   Reply With Quote
Old 10-28-2020, 09:49 PM   #5
expavr
expavr's Avatar
The 4 Speed shift pattern in the Tonner looks like this Reverse is all the way to the right and down. To put it into reverse you have to lift the lever up on the shift arm.
expavr is offline   Reply With Quote
Old 10-29-2020, 07:35 PM   #6
melisahe
melisahe's Avatar
Now I'm am confused, lift up, push down? what lever? I'm a real novice on this. My trans has no lever.
Old 10-29-2020, 07:49 PM   #7
alanwoodieman
depending upon the year of the shift "tower" you may not have a reverse lock out lever that is pulled up. during ww2 the army had ford remove the lock out lever. we recently had a 4 speed in a 39 lock up in the shift tower--rusty-crusty, cleaned all this up and would still not shift into 3/4, turned out the gear was frozen on the shaft in the trans
