Hello! Long time listener, first time caller.......
Can someone explain toe in, and what should be done to the model a, and how, to be appropriate? Thank you in advance! Gene |
Welcome to the club.
Here is a short, short version. Toe-in is where the front wheels 'fight each other' as they are just slightly angled in towards the center of the car. That being said, what needs to be done to your car? A great resource is Les Andrews first book-red I think. It will give you a step by step breakdown. Mike
Your local tire/alignment shop can do the job if the front end parts are in good condition.
here is a online video
I believe that the correct toe in is 1/16" plus or minus 1/32" https://www.bing.com/videos/search?q...tail&FORM=VIRE
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 09-29-2020 at 04:07 PM. Reason: correct toe in to 1/16 plus or minus 1/32 |
Does any body no where to buy a toe in gauge ??
https://www.amazon.com/s?k=Duby+Wheel+Aligning
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
Brent Terry posted about toe plates a while back. I think he uses something like this.
https://www.jegs.com/i/JEGS/555/8168...iABEgKgxvD_BwE Sent from my iPhone using Tapatalk |
A weak or sagging front spring will cause front end shimmy . If the back tires are under inflated , it will also cause front end shimmy . I run my tires at 35 pounds pressure .
I have and use both of these:
https://www.summitracing.com/parts/lng-79620 https://www.summitracing.com/parts/sps-99361
1931 Murray Town Sedan. Black body with Apple Green pin stripe. 1923 Model T Touring with electric start. Low radiator Cincinnati, Ohio |
