Old 08-17-2020, 02:09 PM   #1
Kentmac
Default CCPU safety lock
The doors on my ccpu often open when I hit a bump or make a shart turn. Does anyone make a simple safety lock that could prevent this? It seems that a sliding mechanism could be used as a safety lock without looking too bad.
Kentmac is offline   Reply With Quote
Old 08-17-2020, 02:22 PM   #2
McMimmcs
McMimmcs's Avatar
Default Re: CCPU safety lock
If your door latch is set properly that problem should not exist. I'd start first with your latch!
Old 08-17-2020, 03:01 PM   #3
GPierce
GPierce's Avatar
I installed new latch’s in the door and posts. I have hit some pretty teeth jarring bumps but never had the doors pop open since.
GPierce is online now   Reply With Quote
Old 08-17-2020, 03:19 PM   #4
Big hammer
I put new springs in the latches on my Tudor, doors no longer pop open !
get a bigger hammer tap done
Old 08-17-2020, 04:02 PM   #5
JRShaw
JRShaw's Avatar
Smile Re: CCPU safety lock
My Late '31 CCPU had the problem of the passenger door becoming partially opened when going over any bumps. A very good friend of mine checked the passenger door top fit with the cab. That door had been replaced. By running a folded piece of paper along the top, he found an interference near the cab front. This may be helpful to you.
JRShaw is offline   Reply With Quote
Old 08-17-2020, 07:20 PM   #6
CarlG
CarlG's Avatar
New door bumpers and correct alignment help a bunch.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
