Old 06-22-2020, 02:55 PM   #1
jetrod
Default holly 94 rebuild kit
Hey, I have a rebuild kit for the Holley 94. I has 2 power valves--one has a movable shaft and the other has a fixed shaft. What is the difference in the valves- I have a 1952 F1- EAB block, which one is for my carb (marked EAB)? Thanks, Jerry
jetrod is offline   Reply With Quote
Old 06-22-2020, 03:01 PM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: holly 94 rebuild kit
Only one is the powervalve.
Other one is the sparkvalve for the later carbs.
Old 06-22-2020, 03:13 PM   #3
Fordestes
cancel , wrong place
Fordestes is offline   Reply With Quote
Old 06-22-2020, 06:42 PM   #4
Black Fifty
Black Fifty's Avatar
Jerry,
Be aware of the fact that not all power valves for the 94 are created equal. The one you want needs to have a completely flat surface where it mates up to the bottom of the carb. Newer valves have a "raised" machined surface that won't seal properly to our old carbs and will leak.
If you're not sure what you have, post a pic or contact Sal (scicala) or CharlieNY here on the Barn.
Mike
Black Fifty is offline   Reply With Quote
Old 06-22-2020, 07:10 PM   #5
Jack Shaft
All kinds of issues with modern power valves,from seal to fitment in the float well to opening values not correct.If you have an original or older power valve reuse it,or at the minimum save it
Old 06-23-2020, 07:14 AM   #6
chap52
chap52's Avatar
CharlieNY has power valves that he machines flat.
Old 06-23-2020, 09:03 AM   #7
jetrod
But what is the difference in the 2 valves provided in the repair kit? Jerry
Old 06-23-2020, 09:15 AM   #8
ford38v8
ford38v8's Avatar
There is only one power valve in your kit. The other similar unit is a spark valve that installs on the outside of a later Holley to control the distributor advance.
Alan
Old 06-23-2020, 11:41 AM   #9
scicala
scicala's Avatar
Also, the power valve and spark valves are spring loaded in the opposite direction, so that's a way to tell the difference.
Sal
scicala is offline   Reply With Quote
