Hi all - when I start up my 1931 roadster, I hear a very audible noise that I can only describe as a scraping noise coming from the engine. It is cyclical and does not increase/decrease with engine rpm. There is no effect on performance, and after a few minutes it goes away and the engine sounds fine. I may not be doing the description of the noise much justice, but that's kind of what it sounds like. Any ideas? Thanks in advance!
You might start by taking the tension off of the fan belt and slipping it off the generator pulley to see if it is coming from that area of the engine.
Use a broom handle as a stethoscope, see if you can narrow down where the noise is coming from. Careful around the belt and fan, if still makes it with the belt off trouble shoot with the belt off for safety purposes.
Thanks - will try this weekend
Check your private messages in the upper right corner of this webpage.
Marshall |
Add some more oil to the fitting on the dist.
Paul in CT |
Glad you found the trouble. Myself in your situation I'd be pulling that distributor and look it over.
Dave / Lincoln Nebraska |
I once saw an adaption of a cup type oiler to a Model "A" distributor on this forum. For touring, the oil cup is a good idea.
Bob Bidonde Last edited by Bob Bidonde; 05-24-2020 at 11:34 AM. |
Your upper bushing may be worn. If you can move the cam under the rotor sideways at all, replace the bushings. Easy job.
Thanks again. I'll get right on that bushing and see if it just needs oil or replacing.
If you do not want to rebuild your own, here is an option, allows you to reuse some of the parts on your distributor. $40 + $35 refundable core charge.
https://modelastore.com/index.php?ro...&category_id=0 |
#13 |
Hi all - well, those who know better (i.e. all of you and not me) prevailed! I oiled the bushing inside the distributor and VOILA! no more noise at all - at idle or under a load.
Thanks again!! |
