Old 04-25-2020, 10:48 PM   #1
glassmanjaf
Default 40 ford outside door handle removal
In order to refurbish my doors, I would like to remove the hardware to clean and paint. Most is straightforward, but in getting the outside door handles off, I pulled the small screw out on the side that looks like it would hold the handle on, I would think that it would then wiggle off, but it doesn't. I don't want to try to force it off without knowing fully how is comes apart. Any help would be appreciated.
glassmanjaf is offline   Reply With Quote
Old 04-26-2020, 09:13 AM   #2
deuce_roadster
deuce_roadster's Avatar
Default Re: 40 ford outside door handle removal
If this is a convertible there is a nut on the inside (might be LH thread). Otherwise it is just the square shaft stuck in the mechanism, may be rusted. Take the door panel off and look. You can take a punch and tap on the end of the square shaft.
If this is the passenger side, you didn't remove the set screw that holds the lock in did you?
The screw that holds the handle on is short but is probably 1/4 20 and comes in at an angle.
Old 04-26-2020, 03:34 PM   #3
glassmanjaf
so the shaft comes out with the handle?
Old 04-26-2020, 04:06 PM   #4
4dFord/SC
4dFord/SC's Avatar
Yes
4dFord/SC is offline   Reply With Quote
Old 04-26-2020, 09:39 AM   #5
TJ
TJ's Avatar
Once the screw is out tip the handle downward to the four o'clock position and pull outward. This is how it is done on a closed car.
Old 04-26-2020, 04:48 PM   #6
JSeery
JSeery's Avatar
This is what they look like.
Old 04-26-2020, 09:18 PM   #7
skidmarks
skidmarks's Avatar
I found it easier, after the screw is out and with the door open. Push the latch dog in alittle with your thumb and as you pull the door handle out wiggle it at the same time. Spray it first with a good penetrating oil.
skidmarks is offline   Reply With Quote
Old 04-05-2023, 04:45 PM   #8
MikeT
MikeT's Avatar
Both of mine flop around, any way to tighten them up?
The devil whispered to me'
I'm coming for you
I whispered back,
Bring beer.
MikeT is offline   Reply With Quote
Old 04-05-2023, 06:13 PM   #9
cas3
Replace the spring in the latch
cas3 is online now   Reply With Quote
Old 04-06-2023, 02:00 PM   #10
MikeT
MikeT's Avatar
Do you know of a site that I can look at for replacement?
I'm coming for you
I whispered back,
Bring beer.
Old 04-06-2023, 02:58 PM   #11
50fordcoupeman
50fordcoupeman's Avatar
Do google search. I have seen several vendors that sell the spring replacement kits.
50fordcoupeman is offline   Reply With Quote
Old 04-06-2023, 07:00 PM   #12
JayChicago
JayChicago's Avatar
And do a search of this forum to get some how-to advise. Requires some heating and gentle bending of the lock mechanism to get the spring out.
Old 04-06-2023, 07:43 PM   #13
cas3
Maybe Fred has new ones? Google south side obsolete.
