For a couple days now I have been getting A495 ready for Dearborn. Freed from its trailer, I enjoy sitting next to it each night and reminiscing about the folks who have helped along the way. I think about the places I found all those very rare parts.
Then I thought, this Phaeton has many, many parts and features that were changed to improve the Model A. Side by side how would A495 theoretically "compete" with one of the last Model A's built? Over 4.8 million Model A's were made. The Service Bulletins are full of changes. My question for this thread is...How much better was the last Model A than the first? |
The Auzzies call the 30-31's "the improved Model A". Clutch and motor mounts are the most obvious improvements over early ones. The bigger radiator, to me, is the best improvement.
My wife's grandfather drove nothing but Model A Fords from new up into the early 50's. He owned Model A's from each year, and always said that the 1930 Models were by far the best Model A Fords produced. Those are the ones he'd seek out to own.
----Stainless Steel for bright work vs. nickel plate ----Single disc clutch vs '28's multiple disc ----19" wheels and tires gave the car a stronger stance and better handling ----2 tooth steering sector ----Style. The swooping fenders, smoothed over cowl, belt reveals the entire length of the car, taller radiator and hood transferred into the 1932 Ford, and those things are so sought after for their beauty it is unreal and the prices are sky high ----'Beefier' feeling steering wheel ----improved selection of colors ----wider doors on the Roadsters ----folding w/s on the Dlx. Roadsters ----fender welled spare from the factory on Dlx. models and numerous running improvements. Ford kept the quality high and higher with the best materials available, and continued to hold the line on price. Good thread I'm anxious to hear what others say ![]() |
31 slant windshield fordor is the best Model A built IMHO
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
'31 Budd Closed Cab PivUps
I believe the early 1928 Pheatons did NOT have outside door handles. An obvious improvement.....
Roadsters too until late 28.
"The more things change, the more they stay the same." |
I think the braking system is a big one, independent vs dependent emergency brakes.
#11 | |
![]() Quote:
It would be interesting to find out how diligent, or if, Ford would have addressed the problem if Pennsylvania and other states did not object to the dependent emergency brake. |
Having driven all the years and various models from roadsters to fordors, it is hard to beat a slant window fordor for comfort and road ability. My friends original low mileage 1932 tudor drives just a little better than my restored slant window town sedan.
#13 |
Ford reduced forgings and cheapened the car through production time cuts from 28 to 31,some things got better,as mentioned above..But they held the true advancements till 1932.
#14 |
Reinforcing ribs added and modified in the block, flywheel housing, banjo. As time progressed they learned where the vehicles on the road developed cracks.
#15 |
After just finishing a sever year restoration on a very early '28, I can say that there were certainly many places for improvements to the early cars. I believe that changes were made to increase quality and strength of parts, improve serviceability, and reduce time and costs of assembly. There were also many changes made to reduce the costs of manufacturing.
#16 |
I have 3 Townsedans: '29, '30 & '31 slant windshield, indented firewall; of the 3, I like the '31 the best. This not objective, just my feelings.
Random ROG |
#17 |
Many of the differences were incremental but overall was there a performance difference. I'm not asking what body style or what year you like the best but was there any noticeable difference in how they performed?
Did the later vehicles cool better because they had a larger radiator? Did a change in the differential ratio make a difference? Or was it a 4 year run for a relatively unchanged vehicle? |
#18 |
28 to feb29 roadster, phaeton did not have outside door handles. (1st outside handles started appearing in late 28)
28 thru 29 open cab pickups did not have outside door handles. I do not see the big deal about reaching inside to open the door on an open car, I mean it's right there, not that difficult. |
#19 |
The early 1928 cars may have had a higher top speed than later models, with a 3.70 rear axle, taller tires, 4.3/1 compression versus the 1930-31 head with 4.1/1 compression. Your mileage may vary.
#20 |
Hello I agree with the S/W 1931 Sedan were the nicest looking of all ,Bonnie and Clyde even stole one!!
