Old 05-07-2019, 07:55 AM   #1
Sparky
Sparky's Avatar
Default Why can't my generator move?
My generator is shown in the attached picture. The circled areas show where the generator housing nearly touches the engine at the top and the water pipe at the bottom. Right now everything works fine and the fan belt tension is good, but there is no adjustment possible if the belt wears. Also I have to remove the generator pulley to remove or install the belt. This is a '29 radiator. What's wrong?
Sparky is offline   Reply With Quote
Old 05-07-2019, 08:04 AM   #2
Railcarmover
Default Re: Why can't my generator move?
take the numbers off your belt,go to parts house and ask for one 1" longer.
BX-40 size belt works perfectly
Railcarmover is offline   Reply With Quote
Old 05-07-2019, 08:17 AM   #3
Sparky
Sparky's Avatar
The belt I have is fine. If it was longer I wouldn't be able to get it tight, because the generator can't pivot.
Old 05-07-2019, 08:19 AM   #4
Jacksonlll
Jacksonlll's Avatar
Your return pipe should be a little more rearward. Move it back a bit and that will give room for your generator to swing out. Then get a belt that is a little longer and don’t run the tension very tight. No need to and a tight belt can cause problems. Just tight enough to run things. Good luck.
Old 05-07-2019, 02:30 PM   #5
Ruth
I think JacksonIII is correct. I had the same problem. Slide the water pipe back. As it goes into the engine side hose farther it will straighten out. It also appears to be slightly twisted as the valve should point straight down. Easy to try first before changing out a lot of parts.
Old 05-07-2019, 08:19 AM   #6
Railcarmover
The generator should pivot,loosen the bolt on the bottom.Oh,now I see your problem,your lower radiator pipe is rotated,loosen the clamps and rotate it down to clear the generator.
Old 05-07-2019, 08:53 AM   #7
BillLee/Chandler, TX
BillLee/Chandler, TX's Avatar
You may have the wrong water pipe. Check out the Judging Standards, page 3-7.
Bill Lee
http://www.CedarCreekAs.org
BillLee/Chandler, TX is offline   Reply With Quote
Old 05-07-2019, 09:44 AM   #8
Sparky
Sparky's Avatar
Could it be a pipe for a powerhouse generator?
Old 05-07-2019, 09:50 AM   #9
30 Closed Cab PU
I think Sparky may be on to something. In the picture if you look at the upper hose on the pipe, the pipe seems to be coming out on that hose on an angle.
Incorrect Pipe?
Old 05-07-2019, 10:32 AM   #10
Bob C
See Vince's site for the different outlet pipes. http://www.fordgarage.com/pages/waterpipes.htm
Bob
Old 05-07-2019, 12:11 PM   #11
Sparky
Sparky's Avatar
Bob
I think my pipe most resembles the A-8291-B which is second from the top.
Old 05-08-2019, 11:55 AM   #12
Badpuppy
To my eye it looks more like the top one. But then, you're a lot closer to it than i am.
I believe the dates shown correspond to the three generators used on the model A - Powerhouse (top), "long nose" (second) and "short nose" (third).
Your generator is a short nose. If your car is a 1928 model, it probably had the Powerhouse generator originally.
Old 05-07-2019, 12:19 PM   #13
Patrick L.
Patrick L.'s Avatar
It looks like you have the wrong belt and lower pipe.
Old 05-07-2019, 12:34 PM   #14
Benson
Is it one of those alternators that is stuffed into a custom generator
case?
Case looks larger in diameter than stock.
Old 05-07-2019, 02:14 PM   #15
Sparky
Sparky's Avatar
case?
Nope, stock generator.
Old 05-07-2019, 01:02 PM   #16
Davew
Davew's Avatar
Could the pipe be on backwards? I looked at mine and the long straight comes from the radiator.
Davew is offline   Reply With Quote
Old 05-07-2019, 01:07 PM   #17
30 Closed Cab PU
Do not think so, the drain valve is in the right place. If on backwards it would be on the up slope of the pipe.
Old 05-07-2019, 03:57 PM   #18
Bob C
If your radiator is a 1928-29 you may have a 1930-31 pipe which has the
wrong bend for the radiator outlet.
Bob
Old 05-07-2019, 04:39 PM   #19
Sparky
Sparky's Avatar
That’s what I wondered, but the suppliers seem to sell only the ‘28 powerhouse version and a “one size fits all” 29-31 version.
I’ll try twisting and sliding it and see if that helps.
Old 05-07-2019, 05:41 PM   #20
30 Closed Cab PU
Berts
https://modelastore.com/index.php?ro...&category_id=0
