Just a quick question.
I know a 12 volt Ford with overdrive must use a 12 volt solenoid because a 6 volt solenoid can't handle the higher voltage. How about the relay? Is anyone using a 6 volt overdrive relay with a 12 volt system. Will a 6 volt relay hold up with 12 volts? Thanks! Bill in Conn. |
Both the solenoid and the relay is a coil so will heat up and burn out if used with twice as much voltage as it was designed for.
You can get away with using 6v relays in short periods like a horn relay or starter solenoid but anything used for an extensive period of time must be changed. You could ad a resistor in series with the relay. The solenoid is twin coils so may or may not work with a resistor...since you need larger value for the resistor to get a correct hold function...the draw coil may not get enough to work as it should. |
Thanks! That answers my question.
Bill in Conn. |
The 6 volt solenoid will live for years on 12 volts. The inrush current is to high to use a resister on the solenoid. My results are based on years of use & not here say. Last edited by 42merc; 04-29-2019 at 07:33 PM. |
