02-03-2019, 12:01 PM | #1 |
Oil pan baffle
Before I damage the oil pan is there a preferred way to remove the oil pan baffle so as to clean out the sludge from below? In the book it simply states remove baffle. Also as a side note the previous owner used a bolt with a lock nut to hold oil pump in place as far as I can tell the damage was limited to damaging the threads on the bolt, no cracks in block thankfully. I will replace it with the correct pipe thread plug. Thanks in advance for any information!
02-03-2019, 12:04 PM | #2 |
Re: Oil pan baffle
Place the pan on the floor and put a baseball bat or such in the hole where the oil pump goes through. Use it to pry/pop the baffle out. It is a friction fit with small indents along the sides.
Dave / Lincoln Nebraska |
02-03-2019, 12:14 PM | #3 |
Re: Oil pan baffle
Thanks Dave! took a lot more force than I anticipated but I got it. amazing how much sludge was in pan bottom!
02-03-2019, 12:46 PM | #4 |
Re: Oil pan baffle
Don't do like I did. Installed the pan with nice new gaskets and seals then went to the shelf where the oil was stored and found the baffle sitting on top of the case of oil.
John |
02-03-2019, 01:03 PM | #5 |
Re: Oil pan baffle
Easiest way I have found to remove the baffle without damaging the oil pan is to drop it from about six or seven feet onto dirt and grass covered ground so it lands flat on the gasket surface. The baffle usually pops out on the first or second drop.
AL in NY |
02-03-2019, 08:00 PM | #6 |
Re: Oil pan baffle
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
02-03-2019, 12:42 PM | #7 |
Re: Oil pan baffle
I find it amazing how many people put a bolt in that plug hole to "hold the oil pump". A local 'machinist' did that to my block (among other things I wasn't thrilled about) that I had main bearings installed in . No doubt I won't be using them again.
02-03-2019, 01:07 PM | #8 |
Re: Oil pan baffle
X2 on the drop
Sent from my SM-J701M using Tapatalk |
02-03-2019, 01:15 PM | #9 |
Re: Oil pan baffle
Agree with the drop and then I don't break all of my childhood baseball bats.
02-03-2019, 01:47 PM | #10 |
Re: Oil pan baffle
Dropping can bend gasket flange, bat-rod-pipe-prybar, catch other side of pan under lift--step ledge, running board to hold pan secure and reduce the mess
02-03-2019, 02:08 PM | #11 |
Re: Oil pan baffle
Thanks for all the replies and advice. After getting the baffle out and cleaning up all the sludge I’ve moved onto disassembling the oil pump which was in remarkably good shape bushings and all. The plan is to reassemble everything back into car tomorrow.
02-03-2019, 02:20 PM | #12 | |
Re: Oil pan baffle
Keep in mind the oil galleries and valve chamber are not cleaned - detergent oil in this area will eventually lift the sludge from there and everywhere else to end up IN your oil or at least a thinner coating of sludge on the motor interior generally. That is the point of detergent oil. After converting to detergent oil (should you go this way) 3 changes of oil at usual intervals will mostly clean out the rest of the engine to where you need not worry. Or, forgo a change. You can continue to drop that pan. It works. There are adherents to both theories of operation. Joe K
Shudda kept the horse. |
02-03-2019, 02:52 PM | #13 |
Re: Oil pan baffle
Kurt in NJ: You won't bend the gasket flange if you drop the oil pan on soft ground, not asphalt or cement.
AL in NY |
02-03-2019, 06:31 PM | #14 |
Re: Oil pan baffle
Dropping the pan works well but can make one hell of a mess.
02-04-2019, 10:53 PM | #15 |
Re: Oil pan baffle
But the stuff that comes out the bottom of the pan can be quite toxic----pollute the ground, runoff into streams---not to say it is hard to clean off the face too---I have seen the results
02-04-2019, 09:12 PM | #16 |
Re: Oil pan baffle
I know that you already got it out, but I thought I would share my technique. I put a board across the open pan, then slip a big C clamp alongside and under the baffle. I then gently screw in the clamp, pulling the baffle toward the board until it pops out. It has the advantage to being slow and gentle, without the risk of damage.
Ken
Style beats speed any day, and with a lot fewer tickets. |
02-04-2019, 10:35 PM | #17 | |
Re: Oil pan baffle
02-05-2019, 10:45 AM | #18 |
Re: Oil pan baffle
The sludge killed the grass for quite a while where I dropped the last oil pan that I did . What should be done with the sludge ? If the sludge is put in some sort of container , it will more than likely eventually make its way to the ground when the container fails . If the sludge is burned , the smoke will pollute the air , It is just a messy job ..
02-05-2019, 11:09 AM | #19 |
Re: Oil pan baffle
I would put it in the used oil that goes for recycling.
02-05-2019, 07:52 PM | #20 |
Re: Oil pan baffle
