Old 11-06-2018, 11:18 PM   #1
dave11
Default bulb change
So what is the trick to get the cowl lights apart 30 coupe? Time to replace the bulbs
dave11 is offline   Reply With Quote
Old 11-07-2018, 12:45 AM   #2
midgetracer
midgetracer's Avatar
Default Re: bulb change
There is either a screw on the bottom of tge lens ring or a screw on the back of the light body. once the screw is removed, a small screwdriver can be used to pry slightly on the ring and the cowl light will separate.
midgetracer is offline   Reply With Quote
Old 11-07-2018, 11:52 AM   #3
burner31
burner31's Avatar
I went with the LED replacement bulbs, very nice, very bright.
Just had to widen the hole in the reflector a few thousands with a round file, easy, and they work great.
Keith
Shawnee OK
'31 SW 160-B
Old 11-08-2018, 09:03 PM   #4
Redbird
Redbird's Avatar
Where did you get the LEDs for the cowl lights?
Redbird is offline   Reply With Quote
