I've got a 1928 Roadster pickup that is a survivor. It runs & drives great but the thing rides like a truck (duh). I'd like to hear some ideas to get the rear suspension a bit softer. The goal is to have a daily driver that is not going to be hauling heavy loads. Has anyone tried and eight or seven leaf spring in the rear? What were your results?
New Super Slider springs from Posies will smooth your ride..
http://www.posiesrodsandcustoms.com/
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
double posted.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() Last edited by Chris Haynes; 07-25-2018 at 12:43 AM. |
I have a 7 leaf roadster spring in my '31 RDPU. I agree with the suggestion about the Posies spring.
Charlie Stephens |
The price of that rear spring is $390.95 plus shipping,why not remove a couple of leaves from a stock spring and put teflon inserts in the leaves,might work out just as good.
I reduced it to an 8 leaf and the ride is much improved. If I knew then what I know now I probably would have made it a 9 leaf to allow for the age of the spring, the pickup sits about level now fore-and-aft....I would rather the back was up just a little..... Read all you can about that rear spring and be very careful, treat it like something that can hurt you.... https://www.fordbarn.com/forum/showthread.php?t=182182 I also used graphite lube from John Deere between the leaves..last picture... .
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
I would do as 1955cj5 did. Keep the very top leaf in place as it is contoured to fit in the cross-member. Carefully take it apart to clean and lube it. You may need spacers on the U-bolts that secure the spring to the cross-member so it bolts up tightly???
Bratton's offers two sizes of spring plate,
https://www.brattons.com/seven-or-8-...tom-plate.html https://www.brattons.com/ten-or-twel...tom-plate.html
Thanks for all the tips. I always learn something on the barn.
