Hello!
I am considering the purchase of a '30 Tudor (Standard). Car looks good. Some time ago a prior owner replaced the two rear fenders with fiberglass items. You can't even tell by looking at it...color matched really well, etc... Should I be worried? I have not looked at the car in person yet but will be there this weekend to see. Car runs and drives. Only thing that appears to be missing are all 4 shocks (I know...$240/shock)...car seems to be a good deal regardless...otherwise the car is complete. |
Go for it. Glass or Metal fenders not many people are gonna know or care. Just drive it and enjoy the fun and smiles.
C1-C2 |
Good negotiating point. No problem if you just want to drive it but you will hear about it if you put it in a show. Take and post a a lot of pictures for comments.
Charlie Stephens Last edited by Charlie Stephens; 07-18-2018 at 03:21 PM. |
No worries, go for it.
I wouldnt care. Can always be swapped out later if you wish.
wouldnt worry about the shocks either. |
John |
My 30 coupe has fiberglass fenders and running boards. they are smooth with no cracking like my 28 tudor. my coupe is for go and not show so I am happy
#8 | |
![]() Quote:
I would suggest, if the rest of the car seems ok and is mechanically ok, have at it. Good luck! And the shock thing, a lot of these cars for sale have no shocks, not unusual. There are a lot of posts on shocks and work arounds using MGA or MGB shocks! Do some searching on the forum. Have fun! |
Mine have been on since the late 80's, LF has 1 stress crack. Many people have come up at shows and cruises, tapped the fenders and said "they don't make them like this anymore". And they're straight ! ! ! FWIW
Paul in CT |
Go for it !
I suggest that as you get involved in the car, you won't give the fenders a distant thought. Best of luck.
'30 Coupe |
MANY "modern" cars have PLASTICKY parts that never RUST!
Bill Nottoworry
Keep in mind that should you decide to add a second taillight for safety's sake, you'll need to run a ground wire from the taillight stand to the frame or bumper brackets. Anything metal nearby that will provide a good ground. Fiberglass will not provide the ground you need. 'Had to do this last year to a '30 Coupe with 30 year-old fiberglass fenders.
Marshall |
#13 | |
![]() Quote:
Bill W.
#14 | |
![]() Quote:
Car already has 2nd taillight installed. I don't mind non-original parts as long as it doesn't change the character of the car. Heck, I plan to install a (hidden) USB plug and a suction cup mount for my GPS. If I ever rebuild I'll go with the counterbalanced crank and insert type bearings too...but I don't want A/C, 12volts, hydraulic brakes, etc...
"I have not yet begun to defile myself." -Doc Holliday '31 Tudor, '69 F100, '66 Mustang, '11 Ford Flex |
#15 | |
![]() Quote:
No backup camera! ![]() ![]() |
#16 |
70% of the As I looked at didn't have shocks. In fact the one I bought was shockless. If you are buying a driver, there are several cheaper solutions than Stipes shocks.
#17 |
![]() As a shade-tree (my brother says red-neck) machinist I'm open to rebuilding a set of original shocks. So I will keep my nose to the ground at all the various swap meets. I find the whole argument for/against modern versions of the original Houidalle shocks to be very interesting. Part of me says "only original parts" the budget minded part of me says "don't worry about the judges and go for quality...if not original...parts." Usually original parts are better made than new stuff, so often quality=OEM. At least the math is easy.
