I have a newly purchased 34 pickup with an merc 8BA engine. I have not started to work on the truck yet; rather I am asking questions ahead of time to get a game plan for future.
This engine is an EAC with a stock 4 bolt flange intake manifold which has a 2GC Rochester carb. My question is about the potential for too much venturi vacuum from the carb, thereby "overpowering" the stock distributor; effectively providing "all in" full advance at idle/off idle with no advance curve up the RPM range. Engine is a fresh (under 500 miles) from a local reputable engine builder; hard starting and gutless under load. Certain to be more than one issue here but just wondering. I remember having a similar but reversed problem. Engine had a chevrolet distributor and a stock Ford carb. Seemed like the carb didn't provide enough vacuum to advance the timing. My memory could be wrong about this due to old age...whatever. Anyway, thanks for the comments. |
There was a discussion on here a week or so ago about a related subject. IIRC, someone asked about running a 4 bbl carb with a Load-a-matic, and a couple of the guys who should know said if you used the ported vacuum from a 390 Holley, it would work. I don't know if a 2G has ported vacuum or not. While I am a great booster of 2G's on these cars, I have always used Mallory distributors so I have never had the chance to try this. I do know some of the 2G's I have used have a number of vacuum ports, one of which may be ported vacuum, so you may be able to make it work. I don't know, as I just cap 'em all off. Perhaps one of the carburetor experts on here knows and can point you in the right direction and tell you which version of the 2G and which port you should use. You're not dead in the water yet!
WOW! It's hard to believe how pervasive bad Loadomatic information is! The Load O Matic DOES NOT use only ported vacuum! It uses a blend of venturi vacuum and ported vacuum, controlled by the "spark valve", which adds in venturi vacuum as speed and load increase because ported vacuum drops to near zero as throttle opening increases. So with only ported (or even manifold) vacuum, at full throttle you will have zero spark advance. Instead, what you will have is low power and an overheating engine!
The original Ford and Mercury carbs have special internal passages to provide the proper vacuum signal. Other carbs do not, plain and simple! So either get an original carb or convert to a mechanical advance distributor such as the Chevy. |
What can I say? Some people who should know say that it may work; don't shoot the messenger. This was just a suggestion that it may pay off if the O/P looks into it a little more. I'm not a real big fan of absolute pronouncements.
Sorry tubman, it was not my intent to short the messenger! Rather, I was aiming at the source of such messages. I imagine it's possible to cobble up something to give some sort of spark advance when using a non-stock carb with a Load O Matic, but you won't get the right advance curve for all RPM and load conditions!
#7 | |
![]() Quote:
8 BA engine, Max 1 cam, single carb. I'm running a Stromberg 97, together with a Chev distributor. The Chev distributor is fitted with an adjustable vaccum advance together with a mechanical adjustable stop at the distributor. This adjustable stop is from Charlie NY. These 2 combinations at the distributor give the best application and power curve can be set up very easily. Personally I was not happy with the performance of the Chev distributor when only running mechanical advance. Phil NZ |
Check out posts 3 and 4 in this thread : https://www.fordbarn.com/forum/showt...ghlight=barrel.
It is also theoretically impossible for bumblebee's to fly. |
The 2G carb does have a ported vac port and it MAY be close to the vacuum chart of a 94 carb. ( And all 94s dont use a spark control valve). This post shows the chart of vacuum used on a 94 carb. Pretty low vacuum range at .5 to 3 inches of vac...
https://www.fordbarn.com/forum/showt...ght=loadamatic The 2G is such a good carb i would try it. Many on the forum use the 2G.... |
I know squat about the 8BA/94 carb but I do know the 885 for the Mercs pretty well. They started out in 49 with a dual port vacuum both above and below the throttle plate. In 1950, they updated the set up with a small nylon check valve ball to "valve" between the two ports. One port was below (correction just above not below*) throttle plate vacuum and the other was venturi vacuum. This is the only valve in this particular system.
(* It is above the plate until the throttle is opened slightly which puts it just below the plate while the throttle is open enough.) It may be possible to "adjust" the vacuum signal from a particular port on a non stock carburetor to get close but it is doubtful that the signal would be exactly like the 8BA/94 signal is through out the whole range of operation. It would be easier to modify a Chevy or Mopar distributor to work like one should than worrying about an old Load-O-Matic type. At least a person can use any carb or combo of carbs you want as long as it's tuned to work with the choice. Last edited by rotorwrench; 06-03-2018 at 09:01 AM. |
Question: How much vacuum will there be at the ported vacuum port on a 2G carb at wide open throttle? Consider this: Imagine the 2G carb and Chevy distributor are still on the original Chevy, cruising at 60 MPH. At part throttle, ported vacuum is high so vacuum advance is at or near max. For sake of illustration, let's say mechanical advance is at 20 deg., and vacuum advance adds another 15 deg., plus 10 deg. initial. Now we go full throttle to pass someone. 45 deg. advance will cause severe detonation but at full throttle, ported vacuum drops to zero (or very nearly so) as does manifold vacuum, so vacuum advance goes away and timing advance drops to 30 deg.
Now, if we only have vacuum advance (LoadOMatic) and we just lost our vacuum signal (ported) what happens to the timing? It will retard! At a high enough RPM, air flow through the carb may increase enough to regain some ported vacuum but I doubt it would be the same as the venturi vacuum the Loadomatic was designed for. Remember, venturi vacuum is what opens the secondaries on a typical Holley four barrel so it is a fairly strong signal. |
#12 | |
![]() Quote:
Re-reading my OP...very muddled but I believe I see the issue more clearly. Thanks to all who chimed in. I need all (and more) of the help I can get. |
#13 | |
![]() Quote:
Some good speculation on this post the only way to tell is hook it up and drive it!!! ![]() |
#14 | |
![]() Quote:
#15 |
i believe the vacuum port on the 2GC on my 64 chev 283 is what Holly calls a "timed spark vacuum source" on their 390 CFM carb and that is designed work with a GM canister type vacuum advance, but i do not believe would work so well with a Ford "loadmatic" distributor. just my thoughts. i do know that the vacuum signal on the 2GC is non existent at idle buy do not know what the signal is at higher RPMs.
#16 |
I may be off some here, but i "think" Charlie NY said"ij you want to use the load a matic & run a single 2 bl; run a 1 or 1 1/16 inch y block carb". I had one on my 8ba...worked good?!. Just say'n. m
#17 |
I've been running a 2G for 3 yrs now, with a MSD distributor (HEI clone) running off manifold vacuum It's a great combination, a much better carb than the 94/2110's. If I were in the OP's position, I'd change the distributor to a GM style and never look back. Just think, no PV problems, no leaks, and depending which 2G he has, about a 30% increase in max CFM.
'52 F-1, EAB flathead |
#18 | ||
![]() Quote:
Ross: I am convinced that this the way for ME (just me) to go. I'm placing an order with Bubba soon. |
#19 |
I've been running a 2GC on a bored out Merc intake on the 280 for the past 3 years with a Gm dist set up By Richard and the results are excellent. Been posting the numbers for years, it works.
#20 |
Ol' Ron: would you explain the "bored out Merc intake" part please?
