Old 01-03-2018, 12:58 AM   #1
dumb person
dumb person's Avatar
Default Points block, not integral anymore?
What gives?
http://www.snydersantiqueauto.com/point-block
This was integral on a points plate i had. New ones appear to be fitted later.
Oh.. and the new ones appear to have the points in a different orientation, so the rotor will be a some degrees different.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 01-03-2018, 11:00 AM   #2
Mike Peters
Mike Peters's Avatar
Default Re: Points block, not integral anymore?
I've never seen a points block that was integral to the upper plate. Could you post a photo? The points blocks from Snyders have worked well for me. You can cinch them down tight so the points don't close up while driving. Big improvement over worn out original points blocks.
Mike Peters is offline   Reply With Quote
Old 01-03-2018, 11:34 AM   #3
[email protected]
modela@aol.com's Avatar
Mike,
I think I have one in my stash of disti parts that I can show you next time we see each other. You may need it for your E28...
modela@aol.com is offline   Reply With Quote
Old 01-03-2018, 11:06 AM   #4
Ray in La Mesa
'27 & early '28 plates had integral cast point blocks, later '28 & on had screw on adjustable point blocks. Being able to align the points added to their life.
Ray in La Mesa is offline   Reply With Quote
Old 01-03-2018, 11:59 AM   #5
Mike Peters
Thanks Ray and Dave. I looked it up in the JS and there were photos of the two early upper plates with built in points blocks, and were used until late 28. That's what I love about Ford Barn. Always something new to learn.
Old 01-03-2018, 10:21 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
The forged plates had the points block molded in.
Old 01-05-2018, 04:38 AM   #7
Mike V. Florida
Mike V. Florida's Avatar
Look at the top two;
Old 01-03-2018, 10:49 PM   #8
Bud
Bud's Avatar
Not to hijack this thread but does anyone know of a source for Model B point blocks?
Bud is offline   Reply With Quote
Old 01-03-2018, 11:50 PM   #9
Tom Wesenberg
Try Vince. This link will get you to his site.
http://www.fordgarage.com/pages/aeng...rtcushions.htm
Old 01-04-2018, 10:11 PM   #10
ursus
The Model-B point blocks were mounted integral with the plate by means of rivets. I don't believe that Ford supplied them as a separate replacement part. I have a several of the NOS Ford plates and the point blocks are integral with the plate, but can be adjusted by rotating them on their pivot pins.
