I have a '59 292 motor that may have come out of a truck and I'm having a hard time finding a ring gear for it, it uses a 11" clutch. I ordered one off of the internet and it was too small to expand over the flywheel. I have found another one at NAPA and they list the inside dia. After measuring the flywheel, and comparing that to the listed I.D. it looks like the gear will have to expand .15 total to go over the flywheel. That sounds too much. I did not measure the other gear before I sent it back, but it was too small.
I guess what I'm asking is, is there a difference in ring gears for flywheels that use the 11" clutch? What about if the flywheel came from a truck, maybe even a large truck? |
If you are sure of the year, and you have an 11" clutch, it is from a larger truck, F6 or F7. Not sure of a flywheel difference.
Check this guy, 715-677-3809,,,ring gears are his thing, |
#3 | |
![]() Quote:
I'm sure of year, I checked numbers on the block but the Y block site said it was from a car 1959 or 1960 but had truck front mount and timming cover.. motor could have been swaped into a truck and they kept the larger flywheel/clutch. Thanks for the number |
I have a 6-cyl clutch & flywheel with ring gear out in the garage and I have a Ford-O-Matic converter front plate with the ring gear on it. The ring gear for the Ford-O-matic should match closely with what you should have I think. I will try to measure them both.
#5 | |
![]() Quote:
#6 | |
I personally would not try to burn a ring gear off a converter front plate. If you are thinking of doing that, measure the I.D. of the Ford-o-matic ring gear and compare that with the O.D. of your manual transmission flywheel first to see if it would fit. |
#7 | |
![]() Quote:
No I was not going to try that, you had brought up the Ford-o-matic rear thing and was thinking that was what you were saying. The trans in the car now is a Ford-o-matic but it has the water cooled converter. |
#8 | |
![]() Quote:
Do you happen to see a Casting ID No. at the mounting flange? The Basic PN should read 6384. Need the characters before and after.
***** "Last Sunday, I caught him makin' eyes at Idell Bushey durin' preachin'. And I know what they do up there in the hills when they say they're possum huntin'. They're just sittin' around the campfire, drinkin' hard cider, hittin' each other on the shoulder and hollerin' 'flinch!'." ― Charlene Darling (Daughter of Briscoe Darling) |
Yes, in the recess at the crankshaft mounting flange. This can be crossed to the flywheel PN and once application is determined to can find the ring gear PN by itself.
Example Only- B8T 6384-C
#12 | |
![]() Quote:
I checked and can not see any number. This flywheel was pretty rusty so there may have been numbers at one time but not now. |
#13 |
#14 |
Most of the Y-blocks used the same basic flywheel size but the thing can be drilled for different size clutch covers. FoMoCo made a lot of different Y-blocks but most of the ones for smaller trucks and passenger cars have interchangeability. The Big Job engines like for F7 & F8 trucks and Lincolns, not as much. A 10-inch clutch is plenty good for most Y-blocks anyway.
The ring has to be tight on the wheel. Put he wheel in the freezer and heat up the ring gear and they will generally drop right on there. According to some replacement procedures in older Ford publications. The ring is to be heated uniformly and they mention using a torch but as a general rule 250 degrees F is hot enough so an oven can be used as long as you can talk the wifey into it. Good luck with that. |
#15 | |
![]() Quote:
That is what I'm worried about, this 'wheel may have been off of a large truck. I looked for part numbers and can't find any. When I tried to install the ring gear, I put the flywheel in the freezer over night and got the gear WAY over 250*.... still would not go on. That is what makes me think it was the wrong gear,or I have the wrong flywheel. Now i'm thinking if this is a big truck 'wheel, maybe it needs to be used with the "truck" bell housing to get the starter to be positioned correctly. Any thoughts on that? |
#16 |
The gear that I can buy from NAPA has an I.D. of 13.352" I measured the flywheel at 13.477" so that meand it must expand .125 total. Is that too much?
#17 |
The only thing I can think of is that the flywheel itself was pretty much STD to car/truck of the period. 146T RG is an EAA 6384-A.
GOOGLE the PN and you will find suppliers and maybe can contact them for exact measurements. What are you working on?
#18 |
Thanks, I'll check into that. This motor is in my '30 Tudor and has a Ford-o-matic in it now but I'm swapping in a 3 speed transmission. What I 'm doing now is just getting all the parts together.
#19 | |
![]() Quote:
#20 |
Could just flip that existing ring gear over IF the other side is not worn and tac weld it.
I have not been able to find that ring gear supplier information that I was looking for BUT I will keep looking. Oldmics |
