Old 05-25-2017, 07:14 PM   #1
farmerjohn39
farmerjohn39's Avatar
Default Installing (new) recondition steering arm
When installing a (new) recondition steering arm on the left side of the front axle, this is the one with the two balls welded on p/n A-3131 from Synders, I noticed that there was a grease fitting where the steering arm slides into the front spindle, this would indicate to me that this arm would be free to move, but when I tighten the nut down so I could get the cotter pin in there wasn't any movement. I couldn't find a procedure for installing the steering arm in Les Andrews Red service manual so; my question is; how tight or what torque should the nut be that is holding the steering arm onto the front spindle, or dose the nut just bottom out on the shoulder of the steering arm shaft, or should the nut be backed off a little to let the cotter pin slide into the next slot on the nut ??????
1930 Tudor
farmerjohn39 is offline   Reply With Quote
Old 05-25-2017, 07:32 PM   #2
lindy williams
Default Re: Installing (new) recondition steering arm
I don't have a torque spec but that nut should be very tight. You should not back it off to align the cotter pin. If necessary face off the back side of the nut just a little with a file to get the nut to the next cotter hole.
lindy williams is offline   Reply With Quote
Old 05-25-2017, 07:41 PM   #3
Will Ziegler in LI NY
Will Ziegler in LI NY's Avatar
The grease fitting is to grease the upper kingpin bushing. The grease runs around the steering arm through a groove to the kingpin.
Will Ziegler in LI NY is offline   Reply With Quote
