I read about JD corn head grease for trains and rear end when I went to the dealer I found the grease in tubes. So how do you put the grease in the trains and rear end or do I have this totally screwed up.
The corn head grease should be used in the universal joint housing for the u-joint. Not in the rear end, use 600wt. What do trains have to do with Model A's?
600 wt oil for transmission and rear end. Corn head grease for universal joint
Transmission not trains, trans got changed to trains, will have to reread the text closer next time
Cornhead for the steering box. Warm it up before trying to put in.
I know the voices aren't real but damn they have some good ideas! ![]() |
PS: I do use JD cornhead grease for the U-joint.
Use JD for both the steering box and the universal.
The warning to "never put grease in the steering gear" per Ford Service Bulletins and other sources is well published.
I know a lot of things; I just can't remember them all. 1928 CCPU 82-A 1931 Roadster 40-B Dlx (Canadian) |
John Deere Corn Head grease is made differently than regular grease, like axle grease. It clings to the gears instead of running off when the gears stop moving. It is a different type of grease that will work in a steering box. I am pretty sure it will work fine in a steering box.
Rusty Nelson |
#12 | |
![]() Quote:
But STP is NOT a lubricant. Sorry. 1930 was a good year - but some things have improved since then. Certain greases being one of them. I have greased corn heads using JD corn-head grease and think one is challenged to correctly call it a grease. I don't think it an emulsion at all (like traditional grease.) Joe K
Shudda kept the horse. |
#13 | |
![]() Quote:
http://www.cenex.com/~/media/cenex/f...pds-h9-02.ashx "Corn Head Grease is a carefully formulated lithium 12-hydroxystearate grease with oxidation, rust and corrosion inhibitors, extreme pressure (EP) additives for antiwear and heavy shock loading, and a special polymer to control oil separation during storage. The base oil used is a high viscosity index lubricant which provides excellent stability under various temperature conditions."
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
#14 |
I have dedicated grease gun from Harbor Freight loaded with the corn hd tube. Also, a removable pipe plug in the bottom of the steering gear. Pump until it runs out and then check grease fitting at top of casting. Turn steering wheel back and forth to work in grease.The top "zerk" is installed in a brass "adaptor" that fits the stock thread and can be removed by hand to check level. The steering gear takes quite a bit from the tube.
#15 |
I understand why many of you have changed to JD grease. The stuff works, and works well.
I pump it into the zerk opening until it comes out. |
