Guy's where is the best place to buy bearings , gaskets , seals , shims for my 48 F1 rear axle . I believe its a Dana 41
Thanks Cheers Tony |
Check Randy's R&P, https://www.ringpinion.com/
Not sure if he's the cheapest, but he is very aware of the differences between the D41 in 48-50 F-1's, many vendors are not.
'52 F-1, EAB flathead |
Check with Mac Van pelt.
call charlotte driveline, used to be out on 16 west near the fairgrounds
Dana 41 has the round bowl shaped cover. Dana 44 is more octagonal but I think both have 19-spline axles. Luckily most parts are interchangeable so Mercury and Ford pickup stuff had the same bearing parts for a long time later. The cover gasket is still available. The input pinion seal parts vary from year to year but a far as I know, they can be interchanged in sets depending on what is available. The early seal may not be available but I haven't had to check for a long time so I'm not certain.
