cant seem to find much info on this.want to do a mild built on a 41 linc v-12.how do they respond to a cam ?done quite a few v-12 but only stock.
Check with the people at H&H Flatheads
If for street they can't get out of their own way with a performance cam.
I've always wanted to run an L-100 in a Lincoln V12, However the cam needs some compression to preform well in a V8. But the sound would be in-creadacle.
I think this is the book you need...I'll have to check at home to be sure:
Ocee Ritch, the Lincoln Continental...if that's the right book (fairly easy to find online) it has a set of dyno tests on a mildly hopped H V-12 and even tosses in a reprint of the Ford overhaul book. |
