Old 06-18-2016, 08:49 AM   #1
41panelmark
41panelmark's Avatar
Default 1st haul under new power
Well I went easy on it this round, 4126 pounds of top soil. Truck did just fine but still does not like steep hills, gotta go in low with that much weight but we have had over 6k in it before so it can be done. One day I will figure out how to post videos of the old truck in motion but for now pics is what you get.
Anyhow the old truck has hauled more with an old tired engine in the past. I doubt that I will haul as much as I did when I first got it running a few years back. This load was no problem with the new engine. The weight did not even get the overloads to touch the pads like when I had more in it 2 years ago. Again note the GVW painted on the doors.Not sure how it would have been 18,000 but given the old bed set up having been out on a farm who knows.
My truck weighs in at almost 6 thousand pounds empty now, 1500+ more with the old bed.
41panelmark is offline   Reply With Quote
Old 06-18-2016, 09:15 AM   #2
19Fordy
19Fordy's Avatar
Default Re: 1st haul under new power
Wow! You should name your truck "MIGHTY MOUSE".
Old 06-18-2016, 10:01 AM   #3
34PKUP
34PKUP's Avatar
While in high school, I used to work part time in a Texaco station and we had a '41 wrecker (not as nice as this one).
Seem to recall that it had what was called a 'stump puller' transmission.
We, on occasion, would put it in low/low gear and then walk beside it while it slowly rolled along at idle speed. (ah' the good old days)
34PKUP is offline   Reply With Quote
Old 06-18-2016, 10:33 AM   #4
41panelmark
Old Ford trucks do have that reputation for the low walk. I have a 2 speed rear end waiting to go on the truck some time next year in hopes of a bit more speed on the highway. That will have to wait as I am starting on my 18 T p/u soon.
Old 06-18-2016, 11:12 AM   #5
Ross F-1
Ross F-1's Avatar
Not sure on a truck as old as yours, but on the 48-56 trucks with 2-sp axles, you get "slow" and "slower". "High" axle gear was a lower ratio than the single speed axle. In other words, it won't give you less RPM at cruising speeds.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 06-18-2016, 06:35 PM   #6
41panelmark
Actually I have been doing some research and I have found that some of the Eatons offered a direct that was higher and an under that was lower. Some of the original lit I have shows that I think. Still working on figuring that out.
Old 06-18-2016, 10:30 AM   #7
41panelmark
Hmm, might do that since I don't have a name for it as of yet. Filling it up with broken concrete this morning, nice to drive now with out all of the blow by and the hoist is much smoother since I changed out the hydraulic fluid.
Old 06-18-2016, 10:09 AM   #8
Kurt in NJ
Kurt in NJ's Avatar
The 46 we used for fleamarkets always carried a 2 ton plus load, there were times I was down in first, then it got a 49 merc, made a lot of difference----and that went to work on it's first day with that load--on a road trip to Hershey----the Merc had the vacuum assist om the fuel pump---the wipers worked even at full throttle
Old 06-18-2016, 10:42 AM   #9
41panelmark
The best part about having a dump body. Thought you would like to see it in action. Interior is a bit dirty but serves the purpose. More work to do on the truck and around the place, never ends.
Old 06-18-2016, 11:19 AM   #10
51504bat
51504bat's Avatar
Looks good, Mark. I get the new engine back from the machine shop on Monday for my '39 p/u and I'm looking forward to no more more blow by smell as well. But it will have to wait for a bit since a had a total knee replacement in mid May and I'm still moving a bit slow.
Old 06-18-2016, 11:19 AM   #11
JSeery
JSeery's Avatar
Very cool!!
Old 06-18-2016, 11:30 AM   #12
flatford8
flatford8's Avatar
Great to see 'em workin'!!!!...... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
flatford8 is online now   Reply With Quote
Old 06-18-2016, 02:24 PM   #13
RalphG
RalphG's Avatar
18,000 GVW sounds about right. My dad had a similar Ford, but he newer "jailbar grille" style. It had a wooden grain box and he used to figure it held 200 bushels of grain if he filled it up. Thats 12,000 pounds right there and that leaves 6,000 for the truck. Single speed axle and the old well worn flathead used to frequently boil over hauling a heavy load across the fields at harvest time. No hoist on it either so dad got plenty of exercise shoveling grain when it was time to unload.
RalphG is offline   Reply With Quote
Old 06-18-2016, 06:37 PM   #14
41panelmark
Ok this may explain that number, thank you. I have been curious for sure. The bed configuration when I bought it was very long and large.
Old 06-18-2016, 10:59 PM   #15
47COE
47COE's Avatar
The 18,000 may just be derived from the tires on the truck.
When I first licensed my COE the Oregon DMV asked what tires it had and then licensed it for 18,000. Basically the limit is the total contact area of all 6 tires times some pounds per square inch factor.
The most I've hauled is 5 tons plus the 6,000 for the truck itself. I like to keep it down to a 3 ton load these days.
47COE is offline   Reply With Quote
Old 06-18-2016, 11:06 PM   #16
mercman from oz
mercman from oz's Avatar
Wow, this is cool, a 1941 Ford still earning its keep. Love it.
Old 06-19-2016, 11:36 AM   #17
alanwoodieman
makes me wish I had converted my 41 1 1/2 ton to a dump, hmmmm wonder how much trouble would it be?
Old 06-21-2016, 09:21 PM   #18
41panelmark
Not to hard if you have all of the goodies. I keep running across more of these old trucks, some with dump bodies, some with out. If I had the land I would be in big trouble for sure.
Old 06-19-2016, 12:01 AM   #19
Fredb_
Fredb_'s Avatar
Nice truck. Thanks for posting!
Fredb_ is offline   Reply With Quote
Old 06-19-2016, 11:42 AM   #20
Beater
Beater's Avatar
blast from the past for me. I ran a 41 ton for a lot of years as a dayly runner back and forth to work in the 80s 90s one of my fav fords
Beater is offline   Reply With Quote
