Old 02-22-2016, 10:38 AM   #1
Markymark
Markymark's Avatar
Default 1948 - 1952 truck 12 volt wiring harness choices?...
I'm in the process of a 6 volt to 12 volt conversion...My 1950 panel truck original 6 volt wiring harness is trashed...I want a fuse block and NO cotton insulation...I want a NEW 12 volt harness...
***I'm looking to see what 1950-1952 pickup / truck owners are using for 12 volt harnesses?...
***1.Who have you used?...Ron Francis / Painless / EZ wire / ???
***2.Ease of the install?...how many hours / days?
***3.Customer support?...
Thanks, Mark
Markymark is offline   Reply With Quote
Old 02-22-2016, 10:44 AM   #2
mustang8
Default Re: 1948 - 1952 truck 12 volt wiring harness choices?...
Mark I did the samething last year on my 50 f1, I bought Speedways economy wiring harness and thought it was awesome! Every 6" the wires are labeled, nice fuse panel and only $150 if I remember right, way cheaper than painless.
mustang8 is offline   Reply With Quote
Old 02-22-2016, 11:01 AM   #3
Curt in AZ
Curt in AZ's Avatar
I was in So-California Speedshop and looked at their American Wire kit pn 510-303 if I recall correctly. If you want a custom harness rather than a universal fit this one will work and has circuit protection built in.
Curt in AZ is offline   Reply With Quote
Old 02-22-2016, 11:12 AM   #4
51504bat
51504bat's Avatar
If you want a universal wire kit try Rebel Wire. American made wire and good tech support although I didn't need it when I put one in my '39 p/u. Easy to do and I'm very happy with it and cheaper than the other universal kits I looked at. JMO.
51504bat is online now   Reply With Quote
Old 02-22-2016, 11:40 AM   #5
waterboychuck
waterboychuck's Avatar
I bought an original harness from Sacramento Vintage. It is a duplicate of the original. If you are changing it to negative ground you will have to make a couple of changes but no big deal. Also a reducer for the gauges.
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 02-22-2016, 05:23 PM   #6
Ken Crans
Ken Crans's Avatar
I'm with Chuck... great people at Sacramento, Tech support, Ron makes a complete stock harness for 6 or 12 volt. take you about a weekend to install. Good luck
Ken Crans is offline   Reply With Quote
Old 02-22-2016, 07:43 PM   #7
Kahuna
Kahuna's Avatar
I'm also a big fan of original wiring
Kahuna is offline   Reply With Quote
Old 02-22-2016, 09:19 PM   #8
Diavolo
Diavolo's Avatar
Just a note, 6V wiring is more than sufficient to carry 12V. If you want an original wiring system, don't worry about the conversion. The gauge is heavier for 6V than 12V.
Diavolo is offline   Reply With Quote
Old 02-24-2016, 06:28 PM   #9
Markymark
Markymark's Avatar
I think I Narrowed it down to 2 companies?...Rebel wire and Ez wire...Prices and options seem to be comparable...SO...I still have a few questions...
***1.Where or how did you mount YOUR 12 volt circuit board?...What are some of your functional or Kool idea / applications?...Please post picts...(ALL FORD MODELS WELCOME)(car , Pickup , Rod or restoration)...Need some ideas...
***And are there any other "12 volt wiring harness companies" I should still consider?... Thanks,Mark
Old 02-24-2016, 06:56 PM   #10
gearhead1952
gearhead1952's Avatar
I used original cloth wiring in both my pickup and panel just for ease of installation. More expensive route than the universal fuse block types tho.
gearhead1952 is offline   Reply With Quote
Old 02-24-2016, 08:55 PM   #11
TNDoug
I've used both Rebel & Easy Wire. Both were fine for use in my builds. I've mounted the fuse panel on the left kick panel, under a tilt up seat (easy access and really easy to work on), above the center hump under the dash in an antique cigar box (really cool idea from the owner), on a tilt out bracket under the dash. Just remember--you're going to be into it a number of times so make it easy to get to. I've also used Painless & Ron Francis but it's hard to justify the cost of 2x the other brands.
TNDoug is offline   Reply With Quote
Old 02-25-2016, 10:27 AM   #12
Markymark
Markymark's Avatar
Ron Francis is local to me (about 15 minutes)...Which was one reason I was going to use his harness...BUT...price was an issue...
Old 02-25-2016, 02:48 PM   #13
Markymark
Markymark's Avatar
Just ordered my 12 volt harness from Rebel Wire...Should be her next week!!! Thanks, Everyone!...
Old 03-02-2016, 10:32 AM   #14
Markymark
Markymark's Avatar
Got my 12 volt harness...looking to "mock" up the FUSE BLOCK in the panel truck...(drivers kick panel) BUT... may have issues with possible speakers...or left side of steering column under the dash...should be out of the way???? any other ideas for mounting and possible location??? Photos of your applications would be GREAT!
Old 03-02-2016, 02:22 PM   #15
TJ
TJ's Avatar
Mount it high on the firewall just to the left of the steering column. If your firewall insulator is bad I would say replace it before you wire the truck. In the earlier cars I use the holes on the firewall that mounted the original resistor or circuit breaker. I use a piece of 1/2 inch plywood just a little bigger than the fuse panel. I run screws (usually 1/4X20) through the firewall and into the plywood using nutserts. I also have nutserts on the backside of the plywood to mount the panel to the plywood. I cover the plywood with black vinyl so it blends in with the insulator. If for any reason you need to remove the fuse panel it easily unscrews from the plywood. This method will not interfere with the speakers in the kickpanel
Old 03-02-2016, 03:33 PM   #16
Markymark
Markymark's Avatar
TJ THANKS...I'm just getting back from the garage...that is what I came up with also...I won't need the stock voltage regulator...so I took it off the fire wall...I will use 2 or all 3 regulators mounting holes to mount my 1/2" plywood...I will use the original 1 1/2" wire harness hole...just need a grommet...BUT...the nutserts is a great idea...Thanks for that!!!...I plan on taking some photos...For the next guy...
Old 03-02-2016, 08:34 PM   #17
TJ
TJ's Avatar
Marky, I called them nutserts and I should have said T-nuts. The T-nuts have the barbs that dig into the wood. You can get them at most any hardware store.
Old 03-03-2016, 09:00 AM   #18
Markymark
Markymark's Avatar
I knew EXACTLY what you were talking about anyway...Bought some last night...
Old 03-03-2016, 11:26 AM   #19
Harley Dean
Got mine from Tyree Harris for my 48 f1. He has a add in the v8 Times. Looks like the original and was easy to install.
Harley Dean is offline   Reply With Quote
