Old 12-28-2015, 03:54 PM   #1
Goldhardt
Goldhardt's Avatar
Default Hiding Wires
I am going to be installing turn signal lights on my front bumper. Is there a good way to hide the wire coming from the lights on the front bumper brackets or am I stuck using zip ties?
Goldhardt is offline   Reply With Quote
Old 12-28-2015, 04:24 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Hiding Wires
Use black cloth covered wires and use friction tape to hold them to the bumper arms.
Old 12-28-2015, 04:56 PM   #3
C26Pinelake
Times 2, the Master has spoken! Wayne
C26Pinelake is offline   Reply With Quote
Old 12-28-2015, 04:27 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
I don't have front turn signals on my front bumper (My front turn signal lights are in the headlight buckets) but on my rear turn signals I used a couple of pieces of double sided velcro ~3/16" wide. As Tom suggested I used black cloth covered wires.
(Excuse the dust, just uncovered the car to take these pictures)
Old 12-28-2015, 06:07 PM   #5
Fred K-OR
Fred K-OR's Avatar
I just put the wires in one of the "slip" on coverings (they are split so you can put a wire(s) inside of them) and then use the zip ties to hold them to the bumper brackets.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 12-28-2015, 09:59 PM   #6
1crosscut
1crosscut's Avatar
This is what I have done for the wires to the front signals on my AA truck. Apply a bead of contact cement along the bottom edge of the bumper brackets and another bead along one side of your signal wire. Allow to set and attach. Works like a charm. You may have to do a bit of touch up every couple of years or so. Use a black wire and no one will notice it.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 12-28-2015, 11:47 PM   #7
Terry Longest
Terry Longest's Avatar
Black siliicone worked for me. Used zip ties to hold wire until silicone cured then removed them.
Terry Longest is offline   Reply With Quote
Old 12-29-2015, 09:03 AM   #8
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Like Terry L. I used black silicone adhesive under the front bumper brackets, use masking tape to hold the wires in place until the silicone sets up.
Barry B./ Ma. is offline   Reply With Quote
Old 12-29-2015, 09:44 AM   #9
CarlG
CarlG's Avatar
For the fog lights I will eventually install, I found some stainless conduit like the headlights and horn have, only longer and skinnier. Haven't got them installed yet, so don't know how it will turn out.
I also have some fabric wire covers like is used elsewhere on the Model A that I have run extra wires in. Looks like it belongs.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 12-29-2015, 10:39 AM   #10
Patrick L.
Patrick L.'s Avatar
Original style cloth wire or an old style loom will look period. And regular spring style frame clips can be used and also look period.
Old 12-29-2015, 12:20 PM   #11
Goldhardt
Goldhardt's Avatar
Thanks for the ideas and pictures! FedEx just dropped them at my door so I guess it's time to get to work!
