08-20-2015, 11:55 AM | #1 |
Engine I.D. Help
Hi all, I have a 1928 engine and it has an initials RC before the numbers. Does anyone know what the RC stands for?
Thanks to all that reply> Dennis |
08-20-2015, 12:53 PM | #2 |
Re: Engine I.D. Help
What are the numbers that follow the "RC"? Can you post a photo of the stamping. Could be a rebuilder re-stamping!
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
08-20-2015, 01:57 PM | #3 |
The RC is just before the numbers followed by a star. It is on the block excatly where the numbers should be. The ID reads RC 59848*. I can't post any pictures.
08-20-2015, 02:17 PM | #4 | |
link to Steve Plucker engine assembly data http://www.plucks329s.org/pdf/studie...n%20Charts.pdf A picture would help as the number stamps used by Ford had a specific shape to them. Does the number on your title match the number on the engine? If the shape of your numbers do match the shape that Ford used then some rebuilder put his stamp marks "RC" on. If they do not match then a rebuilder stamped the RC 59848*. See the RG&JS Area 1 Engine page 1-2 revised 2011 attached
08-20-2015, 02:53 PM | #5 |
Thanks for the info. I tried to post pictures in the past with no luck. ( I'm not that good with computers ) I will look at the number 9 when I get home tonight. I see the the 9 was changed at one point in time. I think the #8 looks a little funky also.
Thanks Again |
08-20-2015, 03:44 PM | #6 |
https://www.fordbarn.com/forum/showthread.php?t=38520 -DAN |
