Old 08-02-2015, 08:34 PM   #1
moonshine runner
moonshine runner's Avatar
Default Best way to insulate firewall
Good evening Barners,
Anyone have a suggestion on the best way to insulate or re insulate the firewall on a 56 Vicky that already has new carpet/pad installed?
This is the first summer I've owned this car (Bought it at the end of September last year), and driving the car when the temps are in the mid to upper 90's makes it almost unbearably hot inside the car.
The firewall pad looks good inside the car but man it's sure hot down around our feet so I am sure it's heat from the exhaust manifolds. And this is with all windows down and both vent windows open.
Thanks in advance,
Kevin
"Failure is simply the opportunity to begin again, this time more intelligently".
Henry Ford.
moonshine runner is offline   Reply With Quote
Old 08-03-2015, 07:26 AM   #2
Ford blue blood
Ford blue blood's Avatar
Default Re: Best way to insulate firewall
I had the same problem with a 57 Ranchwagon, found the heater door jambed open on the fire wall side. Got it configured properly and operating as it should and problem gone.
Bill, certified Ford nut.
2024 F-150
2018 Lincoln MKZ
2016 Focus
1961 Comet S-22
1956 Ford Crown Victoria
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 08-03-2015, 06:59 PM   #3
moonshine runner
Thanks Bill.
Kevin
Henry Ford.
Old 08-03-2015, 11:37 AM   #4
Ole Don
Ole Don's Avatar
Buy a small roll of the silver bubble wrap insulation. Vacuum everything you can see on the inside of the fire wall, then wipe down every nook and cranny you can see that is bare metal. Pull the carpet and pad down as far as possible, then cut chunks of the silver stuff to fit all the way up to the top and down under the carpet pad. Fit it in first, then remove it and spray the back with 3M spray adhesive. Keep doing small pieces that are easy to handle with adhesive on it. After a while, it will get done, and yes, it does make a difference. I used this product under the entire carpet with the seat removed. Cover the whole bottom of the car inside.
Ole Don is offline   Reply With Quote
Old 08-03-2015, 06:57 PM   #5
moonshine runner
Thanks Don!!
Kevin
Henry Ford.
Old 08-03-2015, 05:29 PM   #6
miker98038
miker98038's Avatar
The other reasonable option is Peel and Seal roofing material, at the Home Depot. A lot of guys over at the HAMB seem to like it. But it's heavier.
miker98038 is offline   Reply With Quote
Old 08-03-2015, 06:58 PM   #7
moonshine runner
Thank you Mike!!
Kevin
Henry Ford.
Old 08-03-2015, 08:36 PM   #8
JeffB2
JeffB2's Avatar
X2,I used it in my '54 even on the inner roof as I live in Phoenix it was 110 degrees today hold your hand on the roof and you'll be going to a burn unit inside barely warm. I've done the floors with it too. This is a picture below,and no there is no smell here is the article: http://www.jalopyjournal.com/forum/t...terial.711889/
JeffB2 is offline   Reply With Quote
Old 08-03-2015, 09:48 PM   #9
HOTRODPRIMER
HOTRODPRIMER's Avatar
I used Dynamat on my firewall & floors in the wagon. HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell
HOTRODPRIMER is offline   Reply With Quote
Old 08-04-2015, 08:36 PM   #10
frank long island
frank long island's Avatar
the other cheap way is a/c duct insulation
frank long island is offline   Reply With Quote
Old 08-04-2015, 09:00 PM   #11
moonshine runner
Thanks everyone. I heard about the stuff at Home Depot. I may check that out.
Kevin
Henry Ford.
Old 08-05-2015, 06:53 AM   #12
bobss396
bobss396's Avatar
I did my '59 with a new pad I found on eBay. My heater box was out anyway. A definite improvement over the falling-apart-crap that was on there.
Dynamat or something similar should work. With the thin stuff, you may want to double it up.
bobss396 is offline   Reply With Quote
