Old 07-17-2015, 08:45 AM   #1
oldwoodsman
oldwoodsman's Avatar
Question engine knock question
Just curious, at what clearances do rod and main bearings start to knock?
oldwoodsman is offline   Reply With Quote
Old 07-17-2015, 11:16 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: engine knock question
I've seen [heard] them knock at .003" on other engines. These model A engines seem to be able to handle a little more before they get noisy.
Old 07-17-2015, 05:03 PM   #3
40 Deluxe
Depends on oil viscosity, too. And oil temperature.
Old 07-17-2015, 05:11 PM   #4
CarlG
CarlG's Avatar
They put up a pretty good knock when the Babbitt in a rod decides to fall to the bottom of the pan in little bitty pieces.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-17-2015, 05:28 PM   #5
Dave Mc
Dave Mc's Avatar
RE; 29 Business Coupe -my engine was rebuilt before I bought the project , when I finally got it together and running it had a knock, determined it sounded like it was # 2 cylinder. I pulled the pan rolled the engine over and was able to see the rod was tight against the piston Boss , just had to pull that piston and had the boss machined for clearance , good as new now. might not be your problem , just sharing my results
Any man who thinks he can be happy and prosperous by letting the Government take care of him, better take a closer look at the American Indian!" - Henry Ford
Dave Mc is offline   Reply With Quote
Old 07-17-2015, 08:36 PM   #6
Kurt in NJ
Kurt in NJ's Avatar
most likely this means the rod is bent, and that the piston is cocked in the cylinder
Old 07-17-2015, 08:42 PM   #7
Floats
Floats's Avatar
Hi Kurt,
What would cause tods to bend?
Regards
Chris
Cape Town
Floats is offline   Reply With Quote
Old 07-17-2015, 09:43 PM   #8
oldwoodsman
Dave I don't have a problem with my engine, just curious for future reference.
Old 07-17-2015, 09:43 PM   #9
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I've heard tell uf a "ROD BENDIN' GREMLIN"!--Sum times, he fills one cylinder clean full uf WATER & WHAMO!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 07-18-2015, 08:48 AM   #10
oldwoodsman
Bill W.
Probably dog Pee
Old 07-18-2015, 10:28 AM   #11
Dave Mc
Dave Mc's Avatar
Rod NOT Bent , machinist inspected , aftermarket piston problem
