Old 03-11-2015, 01:11 PM   #1
1929
Default compression head?
who sells a compression head thats over 6.1 for a rebuilt insert motor that will look close to the stock head, don't like the look of the head with the fins. Winfield had a 6.8-1, but I heard there is none available.
1929 is offline   Reply With Quote
Old 03-11-2015, 01:29 PM   #2
bettlesr
bettlesr's Avatar
Default Re: compression head?
Red's headers shows the winfield head.
http://reds-headers.net/index.php?ma...roducts_id=264
I have the 6.8:1 crow's foot head and it is great.
Dick
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
Old 03-11-2015, 02:34 PM   #3
wensum
wensum's Avatar
I bought my Winfield 7:1 head from Reds Headers a few years ago.
The combustion chambers were rough and needed polishing, I had to get it machined to clear the pistons, also got the combustion chambers relieved to clear larger valves, and when I finally filled it with water last weekend, it had a pinhole that water oozed out on the top face.
I have drilled down the hole a little way and filled it with JB weld.
Time will tell whether or not that repair is successful!
Whilst the initial cost of the head was quite reasonable, it has ended up costing quite a lot more
Keith
wensum is offline   Reply With Quote
Old 03-11-2015, 02:58 PM   #4
gwhite
gwhite's Avatar
The Winfield and Super Winfield heads look nothing like the originals; spark plug location and bosses are completely different. I believe Snyder's does (or did) sell a hi-compression head that looked similar to stock - and there is always the possibility of finding an old "speed head" (early aftermarket hi-compression cylinder head).
gwhite is offline   Reply With Quote
Old 03-11-2015, 06:48 PM   #5
bettlesr
bettlesr's Avatar
I used a standard head gasket, a solid copper spacer head gasket and then another standard head gasket so I didn't have to have the head machined. Four years and no leaks.
1965 Lotus Elan S2
Old 03-11-2015, 07:47 PM   #6
Y-Blockhead
Y-Blockhead's Avatar
I wonder where your CR ended up after all of that??
Old 03-11-2015, 07:29 PM   #7
1929
thanks for the info
Old 03-11-2015, 09:18 PM   #8
Gary WA
Gary WA's Avatar
Snyders i believe has one now.?
www.whidbeymodelaclub.com
Old 03-11-2015, 10:07 PM   #9
1929
Snyders has 8.1 but only for model T
Old 03-11-2015, 09:24 PM   #10
Tod
I am working on versions that will eventually include a stock looking head that is 7:1 compression.
Tod
Tod is offline   Reply With Quote
Old 03-11-2015, 10:08 PM   #11
1929
Tod
when will it be available?
Old 03-11-2015, 10:19 PM   #12
bettlesr
bettlesr's Avatar
Y-Blockhead
Don't know about the current compression ratio. I do know the bore is .100 over and the pistons stuck up way above a single head gasket.
1965 Lotus Elan S2
Old 03-12-2015, 03:22 AM   #13
colin1928
colin1928's Avatar
Instead of using spacers or fly cutting the head
I normally have piston custom made with what compression height gives me around 0.040" piston to head clearance
custom pistons only cost a little more than std
colin1928 is offline   Reply With Quote
