im installing the pressure plate on my 1930 model A engine. freshly turned fly wheel , new clutch disk. After tightening the pressure plate I measured the finger to top of pressure plate. the book says it should be 5/8''... i am measuring 1 and 3/8 inch. what am i doing wrong.
You probably aren't doing anything wrong. You just need to adjust the fingers.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
that was very interesting but i dont under stand what is ment by the "cover"
"adjust the nut until you get a distance of 11/16", measured from the top face of the rear of the lever, down onto the cover. |
the cover is the outer part of the pressure plate. lay a straight edge across est the outer surface of the pressure plate and measure down from there to the arm where the throw out bearing makes contact. that should be 5/8 or 11/16
Is it possible you have the disk installed backwards?
A piece of aluminum channel threaded for a bolt and lock nut makes adjusting the fingers easy. I set the bolt for a depth of 5/8" to 11/16", lock the nut and then use a thin feeler, such as .010" to feel each arm for a slight drag when it's properly adjusted.
